Home > My Defender > 1997 Ex-MOD 110 restoration + Alu Cab pop top
Page 8 of 16 <123 ... 789 ... 141516>
Heh, heh, I know the feeling Laughing Darren
Post #861731 15th Oct 2020 12:43pm
L110CDL
No worries there db950, at least it helped you decide which way to go Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #861989 16th Oct 2020 7:46pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Thanks again Clayton Thumbs Up
Managed to get some aluminium cubby boxes made for behind the locker doors at the weekend.
Fitted in place and all covered in stone chip.
Hoping to have the tub and side panels on by next weekend so I can get the Alu Cab roof fitted eventually! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #862942 21st Oct 2020 9:03pm
db950
Epoxy primer on the tub...
Then the Raptor top coat...
Post #863101 22nd Oct 2020 8:26pm
L110CDL
Looking good with your boxes all made up and in place, taking on a better look now with the paint on Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #863285 23rd Oct 2020 9:13pm
db950
Tub fitted on today, slowly getting there...
Post #863522 25th Oct 2020 8:17pm
Co1
Looking very smart indeed. Thumbs Up
Post #863564 26th Oct 2020 6:12am
That looks great. I'm not usually a fan of Raptor paint but yours does look very nice, indeed.
The boxes look good, too. My only slight concern would be what looks like a mud trap that's been created between the back of each box and the side of the tub. Perhaps a shield along similar lines to the Gwyn Lewis ones would help? Darren
Post #863573 26th Oct 2020 7:58am
db950
Thank you both, I’m happy with the way it’s looking so far!
You’re right about the boxes. The original fag packet design used the tub as part of the rear of the box but with the strengthening ribs and the fact the wheel arch is not quite 90 degrees made me decide to build it as a separate unit.
Now the tubs in place I’ll see what I can do as a mud shield. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #863615 26th Oct 2020 12:15pm
db950
Bolted a few more bits on...
Seatbox in,
Optimill fuel cap,
Side panels panels fitted, then unwrapped the roof eventually,
And....bolted in place!
Still need to seal it up but need to get the windscreen in first as the shelf that fits inside fits very close to the frame so no chance of pulling the screen rubber in with it in place. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #864713 1st Nov 2020 8:41am
SJS_95
This looks awesome! Alu-cab looks really smart Thumbs Up
Post #864729 1st Nov 2020 9:44am
Looks great Smile Darren
Post #864741 1st Nov 2020 10:57am
db950
Thanks chaps Thumbs Up
Will get more pics of it set up when not rushing against an impending downpour! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #864799 1st Nov 2020 5:18pm
Dinnu
Really admire the attention to detail, all the shiny bolts and hardware.. everything painted before assembly Thumbs Up
Do you plan to give the zinc plated parts some form of clear protective coating?
Only thing that I would have probably done is painted the dampers black. Not a fan of bright colours myself. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #864808 1st Nov 2020 5:47pm
db950
Thank you Dinnu.
Yes, all the chassis and suspension bolts are coated with Dinitrol Korrotec 485 (transparent protective wax) after assembly/tightening, I also do the brake pipes with it.
Your right about the dampers, they do stand out too much for liking too, I might end up painting them! Thumbs Up 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #864813 1st Nov 2020 6:14pm
