Home > My Defender > 1997 Ex-MOD 110 restoration + Alu Cab pop top |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3689 |
Great thread.
15th Jun 2020 6:25pm |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 564 |
Thank you, I appreciate it’s been done and seen a thousand times before so thanks for looking in 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech Instagram @the110camper |
15th Jun 2020 7:02pm |
Chassis now blasted which then showed up the worse than thought condition of the rear crossmember.
New galv crossmember bought and welded on and rear step and tow bar fitted so it all got painted with the chassis. Emptying the shot blast media out! Click image to enlarge Crossmember, Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge All painted, Click image to enlarge Working on the axles, rear diff built back up, Click image to enlarge Click image to enlarge Click image to enlarge 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
22nd Jun 2020 8:59am |
Thank you for having a look!
Reminded me to put a few more pics up, progress is slower than I’d like really...work always gets busier when I’ve got a project going on! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
3rd Jul 2020 10:18pm |
Axles are now completed, might get them installed this weekend.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Just got to press this lot into the suspension arms next... Click image to enlarge 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
3rd Jul 2020 10:25pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6118 |
Nice work.
I love rebuilding axles.... for some strange reason, a fully dressed axle on a trolley looks, just "great", new hoses, painted etc. I built a complete 90 around a rebuilt axle once..... did the axle for something to tinker with in the garage, then thought, might as well do a vehicle around it |
8th Jul 2020 7:23pm |
Thank you, appreciated
I agree, the axles look great built up on a trolley, pity they get covered up by everything else once fitted! Haha! That’s one way to do it, axle first then build around it 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
8th Jul 2020 9:31pm |
Great work, your really smashing it out 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
8th Jul 2020 9:54pm |
Cheers, slower than I’d like but my day job is getting in the way!
Axles are under and connected to the chassis now... Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
8th Jul 2020 10:09pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
what paint are you using on these bits? My 109 thread my youtube channel |
8th Jul 2020 10:32pm |
Hi, all of the black paint used is the same (axles and chassis)
It’s a 2k product called Selemix Direct, available in varying gloss levels from 10% to 80%, I’m using 10% for this which is somewhere in between matt and satin I would say. It doesn’t need any primer or undercoat just goes straight on to bare rust free metal so cuts down on product needed and spraying time. It’s a high quality product with excellent adhesion to any surface, I use it quite a bit! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
8th Jul 2020 10:52pm |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1627 |
Great attention to detail looking forward to watching this build Cheers Paul
9th Jul 2020 7:10am |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1842 |
Some detail and effort is clearly going into this build.
Love it. 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
9th Jul 2020 7:45am |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 407 |
Fantastic progress after less than 2 months. Looking forward to seeing the rest of the rebuild.
Andy |
9th Jul 2020 3:16pm |
