Page 140 of 1383 <123 ... 139140141 ... 138113821383>
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
rossy wrote:
... You'll see Brunel grilles are not available in Ireland but black is growing on me
I actually prefer the look of the black surround/grill myself.
Post #84650 16th Aug 2011 9:27am
Glynparry25
Today I went to the beach to see a shipwreck:
Then a play in the dunes:
Took an 'Arty Farty' photo too :
Hope you all had as fun and exciting Land Rover day as I have Very Happy
Glyn Dog :sheep:
Post #84660 16th Aug 2011 10:38am
Shocked Wow, nice pic (2nd one down) Cool
Post #84662 16th Aug 2011 10:58am
JSG
This morning I went to try the Raptor cubby box I bought at LRMAx. Not convinced it will fit a Pum although Phil at Raptor said it would. The box needs to be offset against the passenger seat to miss the transfer lever and the back takes up too much rear legroom.
Be fine for a 90 but not the 110 Evil or Very Mad John
2011 Tdci 110 CSW XS
Post #84676 16th Aug 2011 12:37pm
spudfan
Ireland
Earning it's keep....
Bringing home turf (peat)...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #84678 16th Aug 2011 12:54pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Glyn Dog Sheep
Great pics Glyn!! love the second one!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  110 Tdci Double Cab
Post #84687 16th Aug 2011 2:05pm
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
What did I do today? - absolutely nothing - just as I have done in it for about 2 months.
This was due to it trying to put me into a hedge - the traction control was coming on, left hand side only, at weird intervals.
SO, to a Landy specialist in Cumnock, Ayrshire.
Knackered rear left wheel bearing & ABS sensor.
That fixed, decided to get it completely cleaned underside & stoneguard on it & clear waxoyl the door panels etc.
All done
And they even fixed the screaming fan belt (3rd belt in 3 months - needed a new tensioner & the grooves cleaned out).
Bill will be chunky, but worth it.
Getting it back tomorrow am - got withdrawl symptoms something awful! 2001 TD5 110 DCPU in Bonatti Grey
Post #84733 16th Aug 2011 6:48pm
Lorryman100
@daviec1
Did the errant reading for the wheel sensor not show up when you checked it with the nanocom? I'm curious as to the refresh rate on the live data for the nanocom as it should have picked up and highlighted the voltages at all 4 sensors showing the faulty one with a lower reading of 2.17volts unless the wheel bearing caused a larger air gap at the sensor but only when moving? Did they rectify the Pump Failure 1 (monitor line), Pump Failure 3 (pump sticking) and the Shuttle valve switch failure DTC's or where they symptomatic of the faulty wheel sensor? Sorry for all the questions, just curious Thumbs Up
Post #84736 16th Aug 2011 7:03pm
Replaced the tatty looking bonnet hinge bolts...
...with shiny new stainless ones Smile
 Darren
Post #84757 16th Aug 2011 7:56pm
spudfan
Ireland
Don't forget to notify your insurance company as the value of the vehicle has probably gone up by at least 50% Rolling with laughter 1982 88" 2.25 diesel
Post #84760 16th Aug 2011 8:09pm
Only 50%? Laughing Darren
Post #84763 16th Aug 2011 8:28pm
daviec1
Lorryman100 wrote:
@daviec1
Will be getting the full story tomorrow, but when I ran the nancom on it, all was well, even with the ABS light constantly lit.
All fault codes are now clear and more importantly STAYING clear.
They have taken it on a lengthy road test to check it all out and have said there is a noticeable improvement in overall performance, so there was something pretty serious going on at the rear left. They completely stripped the entire hub down and cleared all wiring back to do a re-build in essence, as it originally had them pretty stumped.
Certainly, should I need anything again, from stuff like that to complete chassis replacement, they will be the guys to go to.
Big thumbs up therefore for Gibsons in Cumnock. Thumbs Up Thumbs Up Thumbs Up 2001 TD5 110 DCPU in Bonatti Grey
Post #84772 16th Aug 2011 9:33pm
22900013A
I havn't even touched my 110 since Saturday, work has gone very quiet all of a sudden...I may give it a clean though in the downtime, as its pretty filthy with road dirt and bug splatter. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #84798 17th Aug 2011 7:59am
Lorryman100
daviec1 wrote:
Lorryman100 wrote:
@daviec1
Glad to hear your getting the Defender back and the faults seem to be all fixed Thumbs Up
Could you update your original ABS post incase some one else gets the same issues? And having a common thread may help them in understanding the problems and possible fix, cheers Thumbs Up
Post #84856 17th Aug 2011 4:40pm
daviec1
Done
http://www.defender2.net/forum/topic7119.html 2001 TD5 110 DCPU in Bonatti Grey
Post #84861 17th Aug 2011 4:52pm
