Home > Maintenance & Modifications > Heavy duty or single piece half shafts?
Page 4 of 6 <123456>
excossack
From the island4x4 link it says 2002 onwards Rover axle. Is a 1999 axle the same as a 2002 onwards? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #813895 6th Feb 2020 12:08pm
No, they used the Salisbury axle prior to 2002, so completely different I'm afraid. Darren
Post #813897 6th Feb 2020 12:22pm
excossack
Ahh. Is there a single piece halfshaft for a 1999 axle? (off to look) 1999 Defender TD5 110
Regards
John M0VAZ
Post #813901 6th Feb 2020 1:16pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Beginners question as the first time I've had an issue with my rear end Rolling with laughter
I have about 5-degree free rotation on the rear hub before the drive shaft moves.
I have two part half shafts and replaced the end caps 2000 miles ago with new bearings etc.
Is this likely to be half shafts or worth looking at something else first?
Post #813904 6th Feb 2020 1:32pm
It's very likely to be worn drive flanges, although could be the half shafts, too. Remove the end cap and have a look for traces of rust. You may find that it looks like these:
The one on the left is the old one.
If that's the case then you may get away with new drive flanges, suitably greased. The alternative 'fit and forget' solution is one piece half shafts or HD components as described in this thread. Darren
Post #813907 6th Feb 2020 1:54pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
May I remind recent joiners of the used Discovery 2 one piece rear half shaft option. I paid £40 for a pair, delivered, from eBay, and I've been delighted with them in my 2014 110 van (but no off-roading for me so the fact they're a bit thinner than the Defender ones isn't so important).
Post #813923 6th Feb 2020 4:07pm
miker
Not that I've found. Would love a single piece halfshaft, but can't justify the cost of swapping out the salisbury axle for a more modern one!
I have considered just getting the welder out....
Post #813925 6th Feb 2020 4:31pm
excossack
Thats a shame. Looks like new shafts and flanges then. 1999 Defender TD5 110
Regards
John M0VAZ
Post #813972 6th Feb 2020 8:15pm
For a salisbury. I reckon if you were to buy brand new shafts and drive flanges, so they were a nice tight fit, then get them properly welded in place, you'd be OK
I've tried over the yers but with worn ones, and the welds often break (OK, my welding probably isn't brilliant either)
Regarding the play in the flange; when I took mine off the other day, there wasn't much play, maybe 3~4mm on each side. possibly slightly less maybe 2~3mm, but it's made a helluva difference to the drive, soooo much nicer now without half as much clunking on power on/off
Post #813981 6th Feb 2020 8:54pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Just to make sure, does the 300Tdi discovery half shafts fit on the Defender with a rear Rover diff?
Here I have a choice of importing or Bearmach.
Are they good?
I don't do heavy offroading mainly daily driver and overlanding.
Post #921988 19th Sep 2021 1:01pm
yes they will fit. As to whether they're strong enough (especially on a laden 110/130).... there are different part numbers for the 130 and military 110s, so one may assume they're stronger.
But if nothing else some cheapy used disco 300 ones will get you home.
Post #921994 19th Sep 2021 2:48pm
jfh
Thanks.
Do you have the part numbers for the 110/130 one piece shafts?(24 spline)
Post #922003 19th Sep 2021 5:15pm
Oldowner
LR072976 & LR072977
Post #922032 20th Sep 2021 12:09am
jfh
Thank you very much.
Post #922036 20th Sep 2021 5:42am
labrado
Australia 2009 Defender 110 Puma 2.4 SW Fuji White
Oldowner wrote:
LR072976 & LR072977
Hi, the items are described as "rear halfshaft which fits Defender 110 models from chassis number 2A638134 (2002 onwards Rover axle)", but from memory the rear of later defender 110 is not a rover but P38, can anyone confirm if the part numbers are correct for puma defender 110?
Thanks
Post #938481 20th Jan 2022 12:10pm
