Home > Maintenance & Modifications > Heavy duty or single piece half shafts?
Page 2 of 6 <123456>
Mo Murphy
I always use one piece shafts on the rear axle, simply because they are cheap, easy to find and fit and forget.
That just leaves me with the front drive flanges to monitor. I would change those too but I can't really be bothered to go to the hassle of finding and fitting Disco 200 ends (10 spline front diff).
50 Shades of Pennine Grey
Post #693794 16th Mar 2018 5:48pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
diesel_jim wrote:
I think, I'm not 100% sure, that the 110 and 130 have a different part number to the 90 spec one piece shafts, But I was wondering if disco 1 piece (or 90) shafts can be fitted to a 110? (With a Rover/P38 diff axle ,naturally)
Or are they not strong enough?
Does anyone know the answer to this question? I am looking to change the rear half shafts on my 110 but can only find single piece shafts listed for 90's? Thanks
Post #712576 16th Jun 2018 7:02am
Scotm
Just in case anyone else is interested. Following a bit more digging, the part numbers for the later single piece shafts are LR072976 and LR072977.
These supersede the separate shafts part numbers TOB500020 and TOB500030.
It appears these can only be purchased as genuine parts approx £375 each or a Britpart where a pair will set you back for £140 including a 2 year guarantee.
I have ordered a Britpart set so I'll update once I have fitted and run them for a while.
Post #713712 21st Jun 2018 5:24pm
zsd-puma
Do Britpart actually do them?
I ordered some Bearmach ones, from I think Trek Overland. But the shafts that turned up where just the normal 2 piece Puma ones. I sent them back because they're were not what I was after.
Most of the suppliers just seem to use the latest part number on the older 2 piece shafts. A quick google on the part number brings up loads of after market suppliers with them as low as £45, but I expect they would have the same issue that I had.
Post #713721 21st Jun 2018 6:19pm
Scotm
Yes they do. I ordered them from Steve Parker and single piece sharts have arrived in Blue Boxes.
Won't get chance till next weekend to fit.
Post #713723 21st Jun 2018 6:28pm
They're available very cheaply from Steve Parker, here:
https://www.ebay.co.uk/itm/LANDROVER-DEFEN...Swz35bH87R
I can't tell whether they are new, new, take-off, or 're-branded' 300tdi Disco items though Confused Darren
Post #713726 21st Jun 2018 6:31pm
zsd-puma
I just found them on ebay;
https://www.ebay.co.uk/itm/LANDROVER-DEFEN...2762064382
The machining looks really terrible in the pictures. For most of the shaft it doesn't really matter, but the seal surfaces even look rough in the pics.
Let us know how they go, you'll be the guinea pig by the looks of it. Wink
Post #713727 21st Jun 2018 6:33pm
zsd-puma
They're not new take off's the outside face of the drive flange forging is (cosmetically) completely different to the genuine ones. So they may just be re-branded Discover items.
Post #713729 21st Jun 2018 6:35pm
Scotm
Here are close ups of the flange end.
Looks like I will be out with the paint shortly.
Post #713736 21st Jun 2018 7:20pm
zsd-puma
Now they look a lot better machined than the ones in the ebay listing. And they do indeed have an end more similar to the Defender ones than the Disco ones.
I expect the ebay listing uses pictures of pattern Discovery ones.
Post #713745 21st Jun 2018 8:10pm
Whilst browsing eBay on the back of this discussion, I've just come across a breaker selling a set of low mileage genuine one piece shafts. It wasn't an expense I planned to incur until next year but at less than a quarter of the price of brand new, they were too good a deal to pass up Shocked Darren
Post #713751 21st Jun 2018 8:29pm
Scotm
Well done - I had spotted those just after I had ordered mine!
Post #713758 21st Jun 2018 8:45pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I replaced my rear halfshafts for those britpart one piece things a couple of weeks ago. Seemed really good quality and went in a treat. 1953 80"
1987 mini city e
2011 90"
Post #713770 21st Jun 2018 9:52pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
I eventually got a pair of second hand 1 piece Disco shafts from eBay. £28 delivered to my door! Fitted these and very happy with them. A lot of people might baulk at fitting used items, but let’s face it, the rest of my car is used as it is - it was a USED car when I bought it. They done away with the clunks I had been puting up with for a while, and all for under £30 - it’s really a no brainer.
Post #713779 21st Jun 2018 10:52pm
zsd-puma
Well some used items are easy to assess for condition, and easy to replace if they fail. And I reckon these shafts come into that category. I mean a used gearbox is a different kettle of fish and a greater risk, but you should be safe with second hand shafts if they look in good nick, they probably are.
Post #713786 21st Jun 2018 11:42pm
