![]() | Home > Puma (Tdci) > Another output shaft..... |
Jem_90 Member Since: 10 May 2019 Location: Oxon Posts: 54 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge Yup same here, 2.4 USW 2011, 87k miles. Let go all of a sudden whilst doing a three point turn. π€¬ Last edited by Jem_90 on 13th Feb 2020 5:07pm. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17647 ![]() ![]() ![]() |
Looking at the wear in the pictures above, it looks to me as though that was not properly engaged with the spring ring secured in the groove. It's hard to be sure from the photos though.
I do think that improper assembly may be another factor in the failures. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2458 ![]() ![]() ![]() |
Probably one of the worse I have seen! Puma 110" SW
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
JLR customer relations...any comment? Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
Yeah. 'they all do that sir'
"Problem? What problem? There is no problem with the output adaptor shaft." |
just realised. LR are ahead of the game with this eco friendly stuff.
I hadn't realised the drive train was designed to be recycled - you can put it in your sandwich once it fails hence why they made it of cheese. ![]() |
Gloucesternige Member Since: 17 Jan 2020 Location: In the garage Posts: 114 ![]() ![]() ![]() |
I think you'll find ther output shaft is made of cheesecake base, it's the 2.2 oil pumps that were made of cheese. Funny, because this all goes nicely with the jacobs cream cracker clutch.
As for being friendly to the enviroment, the chassis begins returning to earth from day one. Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
I'm going to re purpose it as a Β£700 burr pepper grinder !
and I thought the clutches were digestives by McVites - also go well with oil pumps / cheese
Quite https://www.defender2.net/forum/topic36916.html |
Giby_off Member Since: 05 Apr 2015 Location: Sofia Posts: 63 ![]() ![]() ![]() |
Mine is TDCI 2012 covered almost 112 000 km. Since new, it has a backlash. Decided to go for Lof clutch and Ashcroft output shaft. After the change Defender drives completely different. There is no backlash and it drives wonderful.
Clust had loose springs and here are the pictures of the original output shaft ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Although it does splines look good this I think this shaft is over. Anyway, this will be my last Land Rover \ Range Rover. I am not going to sell it but I will not buy the new s...t which most probably has the same problems. Next time I will take Japanise or US offroader. Last edited by Giby_off on 15th Feb 2020 3:34am. Edited 2 times in total |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20678 ![]() ![]() |
That definitely looks like it's spent its life completely dry with no lube.
Probably like that from the factory. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
sollner11 Member Since: 31 Aug 2019 Location: Bavaria Posts: 7 ![]() ![]() ![]() |
I was curious.
The shaft ( Date of Manufacture = 15.08.2015) was greased at the LR factory. 27.400 miles TD4 2.2 110SW now I'm calmed down ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
