Home > In Car Electronics > Double din shortlist!
Page 3 of 3 <123
PCM
Yep, it’s just a slightly different simpler version of your phone screen.
I added a mud glove box to mine. And popped the usb wire into there.
Hidden away and easy to fit. The glove box has been described in here loads. Took half an hour max and was really really easy, but a great mod to do.
Post #774681 24th May 2019 10:05am
andy---doe
So presumably the USB plugs into the rear of the unit then the wire threads through to where you want it to dangle?
If that’s correct, the downsides I can see are that for a start there is a dangling cable but more worrying is that when the cable breaks (as they do) and needs replacing, you have to remove the facia to plug the new usb in – or am I misunderstanding?
Post #774732 24th May 2019 3:22pm
PCM
Hi Amdy
I'm sfraid I'm not really sure how to help you or even that your concern has any validity. There needs to be a lead to connect your phont to the stereo. Car play doesn't work over wifi/bluetooth.
On mine there is a USB extension running from the back of the stereo to the glove box.. This is to allow you to use either an apple connection or a samsung one. (We use both occasionally)
If you break this then yes you'd have to take off the facia and replace the lead, but at least it's just a lead and not the stereo you'd need to replace. Also only takes 2 ,minutes leterally
Wether it's dangling or not is up to you. Mine is nicely tied in and secure at the back of the stereo and through a gland on the glove box.
I then have a 10cm apple lead connected to this so the wire length is minimal.
Thumbs Up
Post #774798 24th May 2019 10:44pm
andy---doe
OK, I misunderstood – I thought you meant you had the (notoriously crappy) apple lead plugged into the back of the stereo, but you have a male to female USB plugged in which makes more sense and I hadn’t thought of.
Post #775041 26th May 2019 2:14pm
PCM
Ah. Now i understand.
Yes, crappy Apple lead is fully in teh glove box and can be easily replaced. Thumbs Up
Post #775130 26th May 2019 10:06pm
stevec205gti
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Galway Green
PCM wrote:
HI Mev
If youære installing it yourself I'd definitely recommend the half depth models. Fitting it is a breeze. Took me an no time to complete my installation. hardest bit was gathering the pateince to cut the dash for the switch panel.
If youre happy unging google/apple/waze maps on your phone, then the best units with Apple car play / Android audio are the:
JVC unit from Mudstuff (JVC KW-M745DBT)
Kenwood (DMX7018DABS)
Both of these are realy fance. cost the same at about £400 (They are the same unit in reality) Look great installed. they both have no buttons but allow you to touch the screen. They also have a background you can change to a landrover one (or alternative) screen.
If you want satnav built in the price goes up. A lot.... and the units are all full depth double din units so you need to push and move a few bits behind the stereo. Again the kenwood unit DNX716WDABS is great but you can get them that have a DVD player in them too. Screen folds out for access and can also tilt for better viewing angle.
For me, I know where i'm going 99% and if not i plug in my phone with Google maps downloaded offline. I did the glovebox conversion and just keep my phone in there.
It's good as you know you always have the latest map and it shows live traffic info and soon will show speed cameras. Plus it's free.
Total cost for my setup was £400 for head unit.
£30 for a rear view camera
£250 for the double din fascia (Defender upgrades)
£20 for a DAB stereo splitter
Total of £800 and a few hours graft to completely change the look of the interior.
Keep us updated on what you decide to go for.
Hi
Can I ask what splitter you went for? Was it just a simple cable, or one of the ones with a powered box?
TIA
Post #776876 10th Jun 2019 7:53am
newton-tony
United Kingdom 2014 Defender 110 Puma 2.2 USW Firenze Red
I may well regret it, but opted for a single DIN pop out unit (after reading many threads with all the pros and cons etc).
So far very happy with my Pioneer AVH-Z7100DAB.
Only time will tell...
Post #776896 10th Jun 2019 11:53am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
ive got the Pioneer AVIC Z910 DAB - wireless car play, means i can either leave phone in pocket etc, or just chuck it in the air charge dock ive installed.
Post #776904 10th Jun 2019 1:06pm
Mev247
United Kingdom 2011 Defender 110 Puma 2.2 USW Corris Grey
So a little update... Ive bought the Kenwood double din and added a rev camera DAB aerial plus some new spots and rear working lamp.. decided to get my mech chap to fit next week in one go as hes better at the electrics. Ill post some photos of progress as we go. 60 110 XS -61k- Corris - For Ever....
Post #777076 11th Jun 2019 4:28pm
Lops
England 2007 Defender 110 Puma 2.4 CSW Scotia Grey
I’ve replaced the facia and fitted a double din stereo, the only issue I have now is the clock doesn’t fit! It’s bottoming out on the top of the stereo.
Anyone else had this problem? Or know of a simply drop in clock to fill the whole?
Post #777999 18th Jun 2019 2:22pm
bear100
Double dash din for sale Whistle
£180 posted Whistle
 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #778003 18th Jun 2019 2:53pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Most people shave off a bit of plastic from the clock body to make it fit - use a Dremel or similar tool.
Post #778130 19th Jun 2019 1:09pm
Page 3 of 3 <123
