Home > In Car Electronics > Double din shortlist!
Page 1 of 3 123>
Mev247
United Kingdom 2011 Defender 110 Puma 2.2 USW Corris Grey
hi all,
Ive bought the fascia and now in search of the easiest best value units to fit that have nav and bluetooth plus decent music sources. I appreciate this has been flogged to death but latest suggests from the masses most welcome. Thanks 60 110 XS -61k- Corris - For Ever....
Post #773374 16th May 2019 3:07pm
fatboyron
went for the Pioneer but I'm thinking of it get rid of it and getting the new Sony that comes with an aerial so you don't need your phone to be able to use the sat nav
Post #773376 16th May 2019 3:41pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I didn’t want to cut the dash about so went this route 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #773381 16th May 2019 4:28pm
pj2106
Post #773382 16th May 2019 4:29pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
^^^^^ I like that a lot Thumbs Up Cogito ergo sum
Post #773396 16th May 2019 6:14pm
^^^^ Good choice. The only downside is the price, but you get what you pay for. Thumbs Up TheThunderRolls🇬🇧🇺🇸
Post #773404 16th May 2019 7:00pm
PCM
Did a lot of research on this. The best units if you’re doing a home fit are the half depth double din units.
These slide in and have no need to adjust the “stuff” at the back.
I chose the kenwood model below. But jvc do a similar one.cost is sub £400
Post #773415 16th May 2019 7:22pm
Stacey007
I have a Pioneer unit,
Bluetooth
Hands free calling and even reads or sends texts.
Android car play which is what I wanted
Plays music from Amazon Music (either on line or off line collections so no data used)
Use phone via google maps or waze for sat nav. Used it for Annecy road trips.
Reversing camera also
Radio is Dab + unsure what that is but lists the songs etc
Loads of other stuff you can do like change the back grounds, colours etc
From memory around £420 with the Dab aerial
Post #773418 16th May 2019 7:41pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
pj2106 wrote:
Might be a daft question, but does the screen pop out when you select reverse or do you have to do it manually?
Post #773434 16th May 2019 8:14pm
PCM
Hi Mev,
Quick question. Are you after a double din or a single din with a double din pop out?
What facia have you bought
Post #773474 16th May 2019 11:22pm
pj2106
Screen comes out when you turn ignition on so camera just come up on screen when reverse selected
Screen takes about 3 seconds to fold away if you don’t want it open👍 2008 110 2.4 XS Utility (Hagrid)
Post #773487 17th May 2019 6:19am
Mev247
PCM wrote:
Hi Mev,
Double din fascia so I guess the fixed large screen. I want it for music radio and sat nav primarily to 60 110 XS -61k- Corris - For Ever....
Post #774038 20th May 2019 2:21pm
Doc P
Cool!
Post #774097 20th May 2019 7:42pm
PCM
HI Mev
If youære installing it yourself I'd definitely recommend the half depth models. Fitting it is a breeze. Took me an no time to complete my installation. hardest bit was gathering the pateince to cut the dash for the switch panel.
If youre happy unging google/apple/waze maps on your phone, then the best units with Apple car play / Android audio are the:
JVC unit from Mudstuff (JVC KW-M745DBT)
Kenwood (DMX7018DABS)
Both of these are realy fance. cost the same at about £400 (They are the same unit in reality) Look great installed. they both have no buttons but allow you to touch the screen. They also have a background you can change to a landrover one (or alternative) screen.
If you want satnav built in the price goes up. A lot.... and the units are all full depth double din units so you need to push and move a few bits behind the stereo. Again the kenwood unit DNX716WDABS is great but you can get them that have a DVD player in them too. Screen folds out for access and can also tilt for better viewing angle.
For me, I know where i'm going 99% and if not i plug in my phone with Google maps downloaded offline. I did the glovebox conversion and just keep my phone in there.
It's good as you know you always have the latest map and it shows live traffic info and soon will show speed cameras. Plus it's free.
Total cost for my setup was £400 for head unit.
£30 for a rear view camera
£250 for the double din fascia (Defender upgrades)
£20 for a DAB stereo splitter
Total of £800 and a few hours graft to completely change the look of the interior.
Keep us updated on what you decide to go for.
Post #774158 20th May 2019 10:16pm
andy---doe
I would not purchase a ‘pop out’ screen.
I have one and they are slow to pop out and make using the reversing camera hopeless. My unit (Clarion) is now not working and am informed it is a common problem that the flexing cables wear. Getting someone to repair it is impossible (unless anyone can help), so a 4 year old hardly used unit is probably heading for the bin.
I again am looking at double DIN
Post #774201 21st May 2019 11:58am
Page 1 of 3 123>
