Home > In Car Electronics > Double din shortlist! |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 |
Yep, it’s just a slightly different simpler version of your phone screen.
I added a mud glove box to mine. And popped the usb wire into there. Hidden away and easy to fit. The glove box has been described in here loads. Took half an hour max and was really really easy, but a great mod to do. Click image to enlarge |
24th May 2019 10:05am |
Hi Amdy
I'm sfraid I'm not really sure how to help you or even that your concern has any validity. There needs to be a lead to connect your phont to the stereo. Car play doesn't work over wifi/bluetooth. On mine there is a USB extension running from the back of the stereo to the glove box.. This is to allow you to use either an apple connection or a samsung one. (We use both occasionally) If you break this then yes you'd have to take off the facia and replace the lead, but at least it's just a lead and not the stereo you'd need to replace. Also only takes 2 ,minutes leterally Wether it's dangling or not is up to you. Mine is nicely tied in and secure at the back of the stereo and through a gland on the glove box. I then have a 10cm apple lead connected to this so the wire length is minimal. |
24th May 2019 10:44pm |
andy---doe Member Since: 14 Mar 2015 Location: Yorkshire Posts: 188 |
OK, I misunderstood – I thought you meant you had the (notoriously crappy) apple lead plugged into the back of the stereo, but you have a male to female USB plugged in which makes more sense and I hadn’t thought of.
26th May 2019 2:14pm |
Ah. Now i understand.
Yes, crappy Apple lead is fully in teh glove box and can be easily replaced. |
26th May 2019 10:06pm |
stevec205gti Member Since: 31 Jul 2018 Location: Nr Cambridge Posts: 24 |
Hi Can I ask what splitter you went for? Was it just a simple cable, or one of the ones with a powered box? TIA |
10th Jun 2019 7:53am |
newton-tony Member Since: 18 Sep 2016 Location: Wiltshire Posts: 122 |
I may well regret it, but opted for a single DIN pop out unit (after reading many threads with all the pros and cons etc).
So far very happy with my Pioneer AVH-Z7100DAB. Only time will tell... |
10th Jun 2019 11:53am |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
ive got the Pioneer AVIC Z910 DAB - wireless car play, means i can either leave phone in pocket etc, or just chuck it in the air charge dock ive installed.
10th Jun 2019 1:06pm |
Mev247 Member Since: 21 Feb 2019 Location: Wilts Posts: 49 |
So a little update... Ive bought the Kenwood double din and added a rev camera DAB aerial plus some new spots and rear working lamp.. decided to get my mech chap to fit next week in one go as hes better at the electrics. Ill post some photos of progress as we go. 60 110 XS -61k- Corris - For Ever....
11th Jun 2019 4:28pm |
Lops Member Since: 17 Jun 2019 Location: Worcestershire Posts: 7 |
Click image to enlarge I’ve replaced the facia and fitted a double din stereo, the only issue I have now is the clock doesn’t fit! It’s bottoming out on the top of the stereo. Anyone else had this problem? Or know of a simply drop in clock to fill the whole? Cheers |
18th Jun 2019 2:22pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1940 |
Double dash din for sale
£180 posted Click image to enlarge Click image to enlarge 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
18th Jun 2019 2:53pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Most people shave off a bit of plastic from the clock body to make it fit - use a Dremel or similar tool. |
19th Jun 2019 1:09pm |
