Home > Puma (Tdci) > Output shaft - updated genuine or Ashcroft?
Page 2 of 9 <123456789>
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
ashtrans wrote:
A subject I have learned quite alot about in the last few years !
we are now on our 4th version of this kit, the first 3 suffering from occasional random leaks which took us a while to resolve,
I naively assumed the MT82 output shaft would be inline with the LT230 input gear or at least fairly close as the adapter casting between the MT82 and LT230 is doweled front and rear.
It turns out they are not inline and some have quite an error so the LT230 input gear is holding the rear of the shaft to the side, try and visualise what this error means to the male and female spline (the one that wears) at the front of the shaft.
the faces of the spline are rubbing up and down against eachother dry, hence the wear.
There has been lots of debate in the past as to what models and years wear, I this the model and year are irrelevant as it depends were you fall in the tolerance range, some never fail ie these have minimal error, some fail every 25K, these would be way out.
I cannot categorically say that some are out of tolerance as I dont have the engineering drawings but I would suggest many are way out.
next question is what to do about it :
its not easy to correct this error so it has to be 'managed' in some way,
a) assemble with new parts and fancy blue LR grease, better than dry, will last longer but not a long term fix as grease will solidify over time and it will wear again
b) drill and fit grease nipples, better but will need topping up from time to time and I dont think grease will flow around the length of every spline as well as oil would.
c) fit our kit, we have sold over 2000 now and yes we have had some early ones leak but on our latest design this has been resolved and I have never seen one wear out and fail.
Dave
Thanks for your input Dave. Mine is a 2012 at 41k miles now, so far I have no indication of any problems with my output except a high pitched whine in 5/6 gear (or is this me being paranoid after having similar issues with my 300tdi shaft) which is why I was considering changing it while doing the clutch.
If mine was failing at 25k or even now at 40k I would buy your kit in a heartbeat, but I suppose there is the chance that mine "could" be in the small minority and have minimal error and this whine be caused by something else!?
I suppose I'll have to have a good look while its up on the ramp and decide then depending on condition
Post #749965 8th Jan 2019 2:16pm
ashtrans
Site Sponsor
the whine is likely to be the transfer case gears, not shaft related, Dave
Post #749969 8th Jan 2019 2:21pm
deaallen
is there typically any warning before the shaft fails, apart from seeping rust?
Post #749970 8th Jan 2019 2:23pm
WindyJ
Dave
Dave, good to have your input on a detailed post. Appreciated.
Is there a way I can tell which version of your kit I have?
It’s new in it’s box with the nylon straps still on even. Purchases sometime 10/16 - 05/18 when the previous owner had the Defender.
Please also tell me it’s easy to fit Smile
Post #749985 8th Jan 2019 3:30pm
ashtrans
Site Sponsor
Hi,
yes, pls send me a photo of the kit,
Dave Dave
Post #749999 8th Jan 2019 4:52pm
WindyJ
Cool...pm’d it to you. Thumbs Up
Post #750002 8th Jan 2019 5:15pm
ozy013
Australia 2010 Defender 110 Puma 2.4 SW Rimini Red
Nope, no warning, just total loss of drive.....that's why I fitted Ashcrofts about 3 years ago, I do alot of solo offroading in the Victorian High Country here in Oz. I just wanted it fitted for piece of mind. The genuine one that we pulled out wasn't far off from failing.
Post #750016 8th Jan 2019 6:13pm
jst
Its really easy to fit
Once the gbox is out! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #750024 8th Jan 2019 6:41pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
ashtrans wrote:
hank wrote:
I fitted Ashcroft when replacing the clutch and so far very happy
Yes there is a price difference but this outweighs the cost of doing it again and again if you intend to keep hold of the vehicle for at length of time
not only the cost of doing it again but it may fail at a bad time, ie all loaded up with your family about to set off on summer holiday, hard to put a price on this.
Yep, that's why I have just had one of your shafts fitted. Unfortunately as the original shaft was not in bad condition it hasn't made much impact on the bag of bolts that is the gearchange, but I can now tick off one thing that won't break 20 miles from a road and leave a bloody long walk home, or worse!
Land Rover's corporate inability to build even relatively basic things straight and working never ceases to amaze me. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #750053 8th Jan 2019 8:27pm
DSC-off
"There has been lots of debate in the past as to what models and years wear, I this the model and year are irrelevant as it depends were you fall in the tolerance range, some never fail ie these have minimal error, some fail every 25K, these would be way out."
That was the result of our own forum survey last year. Many repeated failures at the same interval, often as low as 25k miles, while some do indeed go on forever.
The survey also revealed that any year or model can be affected. Early failures of 2015 MY vehicles show that the Landrover Paste solution didn't fix it, or seemingly make any improvement!
https://www.defender2.net/forum/topic62521-60.html
Thinking about it, there's much more chance of 3 castings in the driveline having misalignment than just 2 castings.
Adding an adapter between the gearbox and transfer box has 3 times more fit/machining conditions to consider.
My bet would be it's the adapter casting that's causing the issue.
Imagine the conversation, "Yeah, we just need a cheap casting to join these gearboxes together for a few years..."
Post #750066 8th Jan 2019 9:18pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: Output shaft - updated genuine or Ashcroft?
deaallen wrote:
I've heard that the ashcroft kit isn't worth the extra and that this new genuine parts kit works as well if not better
Ashcroft uses a genuine Land Rover part for the kit. Therefore Ashcroft shafts are as good as genuine parts or even better (if you consider the lubrification).
My shaft failed while downhilling in the Alpes.
Fortunately I did not need not an engine break on loose ground.
Land Rover refused a refund and just hide.
The car has only 6 years.
Land Rover product quality / marketing / customer care is rubbish.
Let's wait and see if this changes with the new Defender :::
Post #750094 8th Jan 2019 10:53pm
Apparently the optional "Heritage Pack" for the new Defender will include fast-wearing drive flanges and an adaptor shaft failure simulator, as well as clunky wipers and sundry leaks and rattles. It will be an extra cost factory option aimed at the grumpy old man sector.
Post #750100 8th Jan 2019 11:35pm
hornet
blackwolf wrote:
It saddens me that LR has never taken this problem seriously. There again, even the problem of front hubs breaking off the axle wasn't really taken especially seriously.
But that can be explained now. Since there is no trivial solution for the two badly aligned aggregates, the expense for LR would have been catastrophic from a financial point of view. Stay still and sit out -- It worked!
Post #750139 9th Jan 2019 12:30pm
I don't agree that there was no trivial solution! Since this problem manifested itself sometime in late 2007 when there were still nine years of production to come, it would have been very trivial to tighten the manufacturing spec for the adaptor housing, assuming that this is indeed the part which is culpable*. It might have increased the unit cost somewhat, but not by a significant amount when the overall ex-works cost is considered.
I think it is likely that JLR figured that (say) one vehicle in every thousand came back for this repair under warranty and that it made more economic sense to fix that one per thousand and let the owners cover the costs of the others. If people had started dying because of this fault, it would have been a difference story. I am not personally aware of anyone (yet) being involved in a crash as a result of the adaptor shaft failing, although it could well happen.
I suspect that the axle defect would have been treated in exactly the same way if it wasn't for the more readily apparent seriousness of your front hub breaking off. Even the TSB for this deprecatingly says that if the hub brakes off the driver may experience "a reduction in steering control" or some very similar wording. I would have been more inclined to say that the driver would experince a short period of terror and helplessness followed by a crash and possible injury or death. I believe that there have been a number of accidents as a result of this defect, so the "do nothing" approach may not have been an option.
* Given that both the MT82 gearbox and the LT230 transfer box have been in production for a long time, apparently without any dimensional issues, it does seem likely to me that it is the adaptor housing which is the major part of the problem. it would be very interesting to compare the dimensions of one from a shaft-eating vehicle and one from a non-shaft-eater.
Post #750171 9th Jan 2019 3:30pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Finally a reason to order the new "Defender" Rolling with laughter
Post #750190 9th Jan 2019 5:51pm
