Home > Puma (Tdci) > Output shaft - updated genuine or Ashcroft?
Page 4 of 9 <123456789>
MK wrote:
Does anyone knows where is the geometry gone wrong? I have read Dave´s observations but I do not think they are conclusive. Maybe they are but I do not get it. Gearbox end, extension casing or T box?
I think that any alignment issue is most likely to originate with the extension housing.
I was apprehensive when I changed my transfer box at 150k miles that I might introduce problems, but that was nearly 100k ago and my original shafy is still going strong. I will be fitting a new clutch soon (as soon as I have finished replacing the gearbox on my Disco2) and it will be interesting to see what my original shaft looks like at nearly 250k miles.
Post #768916 17th Apr 2019 7:54am
nitram17
ashtrans wrote:
hank wrote:
I fitted Ashcroft when replacing the clutch and so far very happy
Yes there is a price difference but this outweighs the cost of doing it again and again if you intend to keep hold of the vehicle for at length of time
not only the cost of doing it again but it may fail at a bad time, ie all loaded up with your family about to set off on summer holiday, hard to put a price on this.
If you are so confident in your product why dont you put a free replacement and fitting offer on your product if it fails withon a fixed ? milage?I personally think most would pay the extra for peace of mind!
Post #769210 19th Apr 2019 3:16pm
ashtrans
Site Sponsor
Hi Nitram17,
we are confident in our solution to this problem,
we have sold 2342 of these kits to date and had zero back with any spline wear, Dave
Post #769703 23rd Apr 2019 1:02pm
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Very Happy Great, just what I wanted to hear !
My 90 4 weeks ago (16588miles from new......)
Post #769730 23rd Apr 2019 5:34pm
keith
Just bloody great....
First day away for the holidays and the feckkin output shaft has blown again, for the 3rd time since 2012. Stuck by the side of the road with the kids and dog in Aviemore. Awaiting recovery as we write. Unbelievable, end of holidays then for us as it’ll have to the 4 hrs home. Censored Censored Banging Head
Keith
Post #774736 24th May 2019 4:59pm
keith
Quick and smooth recovery operation from Ross’s Garage.
Even brought us a car for free to continue our holiday.
So it’s gonna be a costly fix again then.
Keith
Post #774745 24th May 2019 6:14pm
LR90XS2011
Bad luck Kieth, are you going to replace it with Ashcroft parts DEFENDER 90 TDCI XS,
Post #774747 24th May 2019 6:27pm
keith
Ooooooh the Big output shaft debate. Rolling Eyes
First 2 were replaced by the stealers so I’m part of the debate now.
No shortage of opinions on which is now best, Ashcroft with its 3000 happy modified customers or Luke at LOF clutches saying that all his cars and customers are using the genuine LR uprated shaft.
Well, I spoke to Luke at LOF today , awesome customer care and great advice. I’d better get my finger outa my backside and get an order in ASAP.
I’ll keep you updated.
Keith
Post #774755 24th May 2019 7:34pm
Caterham
I've not read all of this topic yet - I will do but I think I have the solution!! Very Happy
do away with the adapter shaft and replace it with a rubber tube with a jubilee clip either end - this will obviously over come and issues re; tolerance Thumbs Up
ps obviously it would need to be quite strong. stronger than a mc donalds milkshake straw for example Thumbs Up
and for those of you thinking that's a pants idea it may just be better than JLR's solution Rolling with laughter
Mr. Green
joking aside very interesting - thank you.
Keith, really sorry to hear of you bad luck re the shaft. hope you can some how salvage the holiday.
Post #774762 24th May 2019 7:59pm
keith
“ joking aside very interesting - thank you. “
Coming from the 600miles is possible man Rolling with laughter
Well I gotta have something make me laugh mate. I’ve been in tears since 3pm.
Keith
Post #774763 24th May 2019 8:04pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Keith
I’m going genuine with a LOF clutch! Figured I’d change it same time as the clutch after 100k Miles. Interested to see what the state of the original one is in....
Post #774769 24th May 2019 8:36pm
What is different about the "upgraded" genuine shaft?
I don't think JLR has ever changed the design of this part, the only difference was the addition of a sacher of lube.
Post #774790 24th May 2019 10:03pm
Retroanaconda
Not sure what’s more intriguing - the fact that Land Rover were able to bodge the fitting of the gearbox so spectacularly in the first place, or that people even consider not fitting the Ashcroft kit after they’ve gone to the trouble of fixing the bodge. Confused
Post #774794 24th May 2019 10:30pm
lohr500
I no longer have the Defender, but if I did and the output shaft failed, I would definitely fit the Ashcroft solution.
If, as suspected, the issue is caused by poor alignment, then surely any solution which relies on a one time application of grease is only going to prolong the time between failures. Won't the grease dry out/get pushed out over time?
The time/hassle/cost of getting the box out to replace the shaft would more than offset the extra cost of the Ashcroft kit in my opinion.
Post #774834 25th May 2019 9:19am
DSC-off
Re, Genuine Uprated shafts. - if there is such a thing, or if it is just a dab of lube paste.
Does anyone know when this fix was introduced?
It certainly doesn't fix the problem completely. Our forum survey has had replies with failures of shafts with the blue paste.
There is also a high number of 2015 models that have failed.
Personally, I wouldn't take the risk with a Landrover part, if it has gone once it will go again at similar milage.
Keith, sorry to hear of your troubles, and multiple failures.
Can you confirm the milage when each failure occurred please.
I'm sure it will be a repeating pattern. Neutral
Thanks.
Post #774848 25th May 2019 11:06am
