Home > My Defender > An Anorak's Utility Station Wagon
Page 13 of 57 <123 ... 121314 ... 555657>
L110CDL
Cool Thumbs Up Clayton.
Keeper.
Post #736256 22nd Oct 2018 9:31pm
I've spent some of today prepping and painting something for a future project:
In between coats, I spent a few minutes applying a few stickers. Firstly, something to break up the blandness of the wheel cover:
There was a high degree of faffing with masking tape and a tape measure for that one.
Then, a bit of colour for the front wings:
All good fun Very Happy Darren
Post #736523 24th Oct 2018 6:34pm
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
Thanks for the tip on the festoon LEDs... just bought a set too. 👍
Have just fitted a cheapo set last week but they are such a harsh white colour I cant live with them.
Post #736577 24th Oct 2018 9:34pm
Front Grill, Headlight Surrounds and Headlights
So, today was the day for a project that I've been collecting bits for for a little while, which was a 'retro' front end inspired by my old Stage 1 V8:
I picked up a couple of Series headlight surrounds some time ago (one from an autojumble and another from JeremyJ of this parish), which I'd cleaned up and sprayed satin black. However, the little horn louvres on the headlight panels of later models means that just swapping to the earlier surrounds would leaving gaping holes in the front panels. Shamelessly pinching an idea from forum member JWL, I therefore adapted a couple of standard headlight surrounds by cutting them to received the Series parts and painting them to match the body colour. This picture was taken part way through the process, which saw them plastic primed, regular primed, given a couple of coats of Orkney grey from a rattle can, flatted off and finished with clear lacquer:
I picked up a good, used set of Wipac crystal headlights to fit whilst I had it all in bits:
And some stainless mounting rings, although I discovered that the original headlights also had a set fitted:
And then, finally, a stainless, powder coated mesh grill kit:
Oh and a bag of plastic Loknuts to complete the fixings for the Series surrounds.
The grill kit is very nicely made and comes with comprehensive instructions. It's the same as the one supplied by Defender Upgrades but was significantly cheaper direct from the manufacturer via eBay, Lockwood International.
Included in the kit are six plastic fir tree plugs for the holes in the grill frame that are left when the original grill is removed. As supplied, they're black but as I had the paint, I decided to prep and spray them Orkney grey so that they don't stand out so much:
With the existing front panels removed, the new headlights were fitted and the extra Loknuts inserted:
To protect the newly painted plastic headlight panels, I fixed closed cell foam to the rear of the side and indicator light plinths:
The new grill is secured to the frame with little stainless steel 'L' shaped brackets and matching nyloc nuts and Allen bolts. The only deviation from the fitting instructions was that the two lower brackets were fitted backwards as they sat more flush with the surround:
The finished result is exactly what I hoped it would be:
The headlights are also really good (I've had these before on other Land Rovers) but will eventually be fitted with a custom made relay loom.
And a wider view to give the full effect:
 Darren
Post #738660 4th Nov 2018 9:17pm
mini Anaconda
Very good! Bow down Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #738673 4th Nov 2018 10:17pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
What a great comprehensive guide to making a great LR - Love the electrics side... may have to re-read when I come to do my second battery... Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #743417 1st Dec 2018 3:46pm
Zed
I'm really enjoying this thread and in particular your attention to detail. Excellent work, kudos to you. However that front end looks off to me. Perhaps a little too much going on? I get the homage to your old V8 but maybe the lightguards suited the original grille better.
Just a thought. Keep up the great work. Definitely an inspiration.
Post #743425 1st Dec 2018 3:56pm
Thanks, I think Laughing Darren
Post #743464 1st Dec 2018 8:06pm
JOW240725
It's good to see the series and later surrounds together, not seen that before. Be interesting to see what it looked like all in Orkney Grey rather than the bits of black. Thumbs Up James
Instagram @suffolk_rovers
Post #743477 1st Dec 2018 9:39pm
It would look as bland as a really bland thing. Grey on grey on grey Sad Darren
Post #743508 2nd Dec 2018 10:24am
JOW240725
I quite like grey on grey on grey Thumbs Up Bow down
I quite like grey on grey on grey Thumbs Up Bow down James
Post #743534 2nd Dec 2018 12:38pm
seriesonenut
James, is that a new project........ Very Happy 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #743540 2nd Dec 2018 1:13pm
L110CDL
^^^ Question Question Clayton.
Keeper.
Post #743864 3rd Dec 2018 11:09pm
I think this is one of those times that the phrase 'each to their own' was invented for Laughing Mind you, at least that one has the correct colour of indicators Whistle Darren
Post #743924 4th Dec 2018 10:58am
JOW240725
Absolutely, each to their own! Thumbs Up Bow down James
Post #743928 4th Dec 2018 11:02am
