Home > Puma (Tdci) > Another output shaft.....
Page 9 of 18 <123 ... 8910 ... 161718>
DSC-off
£355 plus fitting is an expensive consumable part every 25k miles.
Certainly not something you can do on the side of the motorway if it goes pop in the third lane while overtaking.
It's damned dangerous and needs sorting properly.
The MT82 gearbox is fitted to all sorts of vehicles, 2wd and 4x4, the problem isn't there. It is LR's adaptation to make it match an old transfer box on the cheap, that's where the issue is.
"I wish I had the money to get a proper Land Cruiser"
Yes, that would fix it.
Post #720555 30th Jul 2018 9:32pm
I'm surprised that nobody's suggested or tried simply welding the two parts together. Once the female part is bolted to the back of the gearbox, the male part could be inserted and welded solid. You'd have to be careful not to cook the seal, and getting it off in the futurewould mean cutting, but it might last longer.
Post #720560 30th Jul 2018 10:00pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
When my spline failed the workshop suggested a weld. As an emergency fix.
Not to be a long term solution in their eyes.
P.S. These guys were techniciens for harvest machines (where this sort of spline is quite common).
Post #720578 30th Jul 2018 10:48pm
MK
Who knows if there is a relationship between failure and remap..... Puma 110" SW
Post #720587 31st Jul 2018 12:16am
There doesn't seem to be.
Un-mapped vehicle fail just as frequently as mapped ones.
Post #720613 31st Jul 2018 9:07am
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
I'm changing mine for the third time at 180,000km's.I think there is more to it personally,all of mine have worn the last 1'' of spline suggesting the shaft walked out of the cup before failing.I'm going to fill my next one with moly grease and seal the coupling with high temp silicon and shrink wrap the whole lot.I really think it needs a circlip to hold it together.
Post #720654 31st Jul 2018 11:53am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
That’s what usually happens, the large clip is obviously not strong enough to keep the shaft in place,
On every one I have done, the shaft is never fully home, and the wear is only on the outer part of the cup.
I personally think a stronger clip might just solve the issue, then it would be transferring power through the whole unit, rather than half of it!
They seem to be sufficiently strong enough to start with, but over time must weaken enough to eventually let go. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #720673 31st Jul 2018 1:13pm
PAT303
I'm going to put an O ring under the clip on my next one to hold it out,willing to try anything now.
Post #720788 1st Aug 2018 12:19am
That is interesting. Another possibility would be to drill and tap two diametrically-opposite holes the cup, aligned with the groove for the ring, and fit two retaining screws, lockwired in place.
I suppose some kind of thrust bearing fitted in the input gear bearing carrier in the transfer box would have the same effect.
Post #720807 1st Aug 2018 8:47am
ian series 1
This was the last one I removed, it’s the same one that is in the beginning of this thread.
You can clearly see how the shaft had popped out, and only part of the shaft has worn away,
When the cup and shaft are fully home there is absolutely no lateral movement,
Pull the inner shaft away from the cup about half way, and you can get a small amount of side to side movement, this is what I personally think happens, add in some dust, and fretting, the splines simply can’t take the torque anymore.
If I ever do mine again, I would be inclined to run a weld around the top and bottom?
 80" 80" 86" 88" 90"
Post #720816 1st Aug 2018 9:30am
When I last inspected and greased mine, some three years and 80k miles ago, I had significant difficulty getting the joint apart and it required some major slide hammer action.
I wonder if some of these fail because they are improperly assembled and simply not fully inserted.
Post #720820 1st Aug 2018 10:03am
ian series 1
That’s what I personally think the problem is?
When assembling a new one, as you have noticed, once the cup and shaft are together they are almost impossible to get apart again.
Nearly all the ones i have done, the shafts are always half out, and the plastic cover is just a chewed up mess! if you push them back in to place the clip doesn’t hold.
They must weaken with age? 80" 80" 86" 88" 90"
Post #720822 1st Aug 2018 10:24am
DSC-off
Very interesting theory Ian.
I'm wondering if the corrosion / powdery rust in the splines allows enough movement to 'work' the ring and pull the joint apart.
It also got me thinking about the housing in the Ashcroft kit, would that keep the shaft in the cup?
It appears to tighten on the cup, not actually holding the shaft in place, just intended as a seal.
If there is only a small end float clearance to the shaft then it would serve a double purpose if the joint did come apart.
I suppose it depends on how much clearance there is.
Post #720885 1st Aug 2018 7:54pm
ian series 1
Thanks for posting some pictures of the Ashcroft one,
I’ve only ever re fitted genuine shafts, so never seen the Ashcroft offering Thumbs Up
I’ve got an old coupling under my bench, and I am going to try a few modifications of my own over the next day or so. Whistle 80" 80" 86" 88" 90"
Post #720922 1st Aug 2018 10:30pm
DSC-off
There's more pictures on the Ashcroft website and an article fron LRO about fitting it.
https://www.ashcroft-transmissions.co.uk/m...t-kit.html
https://www.ashcroft-transmissions.co.uk/f...?769007971
It looks properly sealed with 4 o rings to keep the oil in.
Post #720926 1st Aug 2018 11:02pm
