![]() | Home > Series Land Rovers > And away we go again! S3 V8 project... |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Top job
![]() 1995 110 300TDI 1995 90 300TDI |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
![]() ![]() Nice one! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 ![]() ![]() ![]() |
Sounds pretty good to me, & it'll sound even better when "the pedal's to the metal", under load!
Pickles. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10872 ![]() ![]() |
That sound was heaven Ian, i had to listen to it 3-4 times then my youngest daughter had to listen to it a couple of times, she just loved it
![]() ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 490 ![]() ![]() ![]() |
Hi Ian,
How's your S111 progressing? Happy New Year Andy ![]() |
Hi Andy
Happy new year to you too ![]() I've spent the best part of my Christmas holiday working on the series 3! I've had all sorts of problems from a non functional dash (poor earth in hazard switch) This took a long time to find the culprit! Amazing how one earth in a switch can cause no end of grief, To number 5 cylinder with a stripped spark plug thread.... ![]() ![]() ![]() All good now though, which is a relief! I managed to get a reverse spark plug thread tap, which was an amazingly simple but clever tool, Other than that it would have been a head off job. All things going back together nicely, Just 2 outer wings, and doors to paint, and cab roof. Fitted some sound deadening to the bulkhead, and footwells, Decided to carpet the whole cab like a Defender. I'm going to set myself a goal and aim for an MOT at end of Jan! ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
Coming along nicely. I see you have some (K&N ?) filters fitted. Did you run it with the normal air filter/box previously and if so are the K&N,s much noisier? The reason I ask is I was considering these rather than the huge air filter arrangement on my V8 90.
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 761 ![]() |
Hi Ian,
Have you considered a Wright Off a Road/ Exmoor matting system? Quite expensive I know but I've used them in several defenders and have been impressed with both sound and heat deadening, also hard wearing and easy to clean. Andrew |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
I found one of those reverse tools too......didnt know they even existed.....but glad also that they do
![]() ![]() ![]() K&N's allow you to hear those SU's sucking the mixture ![]() ![]() ![]() |
Carpet is a brave choice
![]() It looks really nice Ian, kudos to you, fingers crossed for a good month of spannering and a trouble free MOT, don't do what I did and run out of fuel on the way ![]() Happy New Year |
Believe it or not, I have just brought an original air box assembly for it! I'm not a big fan of the aftermarket air filters, they were only EBay specials, I'm not sure how they would cope with muddy water? I think the induction noise on a run would get a bit tedious, it's going to be bad enough listening to the noise at the back! plus I've read on the V8 forum that there should be a slight restriction with the SUs to run better? When you look at the size of air intake on a standard set up, it makes you wonder? Andrew, good to hear from you. (See your doing well with the CLR appearances!) ![]() ![]() I did look at the Exmoor set up, but I've chopped the bulkhead around quite a bit, meaning I would have to drastically take the knife to it! ![]() Romadog, Glad some clever sod thought of that! I've had a stripped thread in one before many years ago, and was always waiting for it to blow the plug out ![]() I'm not sure if it was like that before, or when I changed the plugs it picked up taking the old plug out? Luckily it was just the first few turns that were damaged. ![]() Wanted, Forward Control Anything considered. |
Cheers Greeni.
Happy new year to you too ![]() I've got a Gunson colour tune at work, it's running way too rich at the moment, So I will get that sorted next weekend. I put 25ltrs of petrol in on Christmas Eve, Gauge is now showing empty, with the fuel light on. I've only had it on tickover not ever been out of first!... ![]() Wanted, Forward Control Anything considered. |
Great progress Ian,
Work for a rest on Tuesday!! ![]() Ali heads stripping is always a nemesis I guess a little anti-seize and correct torque will help but I have still stripped threads. Andy ![]() |
