Home > Series Land Rovers > And away we go again! S3 V8 project...
Page 13 of 13 <123 ... 111213
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I wanted to put a tilt on it when I did it,
But I was over ruled by her ladyship! Big Cry 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #721535 5th Aug 2018 11:35am
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
Looks great mate ! Bow down
Stephen.
Post #721892 7th Aug 2018 8:01am
ARC99
[quote="ian series 1"]Update,
I’ve sent off all the requested paperwork to DVLA in the week, so fingers crossed I can get it on the road soon?
Today I got around to finishing off all the little bits, the new seatbelts needed finishing off, setting up the tracking,
Fitting the centre console tray, and wiring up the heated seats.
One thing that desperately needed doing was cleaning the carbs out, I did do it last year but didn’t replace any parts, it was very hesitant pulling away,
I stripped them down this morning, and fitted a SU overhaul kit, and set the carbs up, which has made a great deal of difference.
It now revs cleanly and is very responsive, so well worth doing,
Revs are still slow to return to idle though, so I might try a thinner oil in the dashpots?
Hopefully now, as soon as I get the V5 I will take it straight down for testing,
And get it out on the road for a shake down.
Both Carbs are quite worn inside, and had plenty of muck inside, i think the main problem was the needles having a film of varnish over them, which was making them stick?
Oh the dekight of carbs .
I remember my father soaking the needles in white spirt as he said that the needles were gummed up with residue from the petrol which looked like varnish he would then rub the needles with a cloth and they looked like new.
He would also use 3 in 1 oil in the dash pots as it was a very thin oil. Don't make old people mad.
Richard
Post #721898 7th Aug 2018 8:21am
ian series 1
My old 1976 Range Rover ran a pair of Strombergs, the only thing they would run properly on was LIC32 Hydralic fluid.
I read that if they are worn, to try 20w50 which is what I did, but I think is a bit too thick, and keeping the revs up?
I need to experiment with a few other grades,
Too thin and it just disappeared Mad 80" 80" 86" 88" 90"
Post #721904 7th Aug 2018 8:56am
