Home > My Defender > Oakseywicks Bonetti 110 XS & Java black 90 special vehic |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
So today I final got too drop the 90 off at the garage to get the new clutch and dmf fitted. Can't wait to get it back and be able to drive it properly again without worrying about a slipping clutch.
17th Aug 2017 7:16pm |
So finally got the 90 back at the weekend new clutchfix HD1 cultch and valeo dmf fitted. It also needed a new clutch fork and pushrod as they were badly worn and had been causing a noise when using the clutch. Got to say new clutch and dmf combo is working like a dream.
Click image to enlarge Click image to enlarge Click image to enlarge I have now noticed there is a vibration noise coming from the gear stick when accelerating hard particularly in 3rd and 4th, it was there before clutch was changed and thought that was the cause but it wasn't any ideas Last edited by Oakseywick on 31st Aug 2017 6:45am. Edited 1 time in total |
30th Aug 2017 7:25pm |
Van Whalen Member Since: 16 Apr 2017 Location: Melbourne Posts: 29 |
Have you glued the weights at the base of the gear stick yet? Common cause of gear stick rattle.
See http://www.defender2.net/forum/topic27350....ick+rattle |
31st Aug 2017 2:48am |
The weights issue is on puma gearsticks is it not? Mine is a td5 does the td5 also have weights?
31st Aug 2017 6:44am |
So I got time today to fit my birthday present from swmbo to the 90 I think it's a big improvement what do you think?
Before Click image to enlarge After Click image to enlarge Click image to enlarge Click image to enlarge |
20th Nov 2017 8:14pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
Much better imo Clayton.
23rd Nov 2017 10:52pm |
Cheers Clayton nice too know someone reads my thread
23rd Nov 2017 11:41pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 |
lovely steering wheel.. 1993 200Tdi Defender 90
24th Nov 2017 1:09am |
Got home from a few days away with work to a nice lot of goodies
Click image to enlarge Click image to enlarge The 90 is in the garage today for MOT and they are fitting the slick shift while trying to eliminate the annoying vibration from the gear stick. So fingers crossed it will come back feeling nicer too use with no advisory |
22nd Feb 2018 5:07pm |
So the 90 passed and the gearstick vibration is sorted out with the slick shift fitted not had a proper chance to test it out yet though so will report back.
23rd Feb 2018 10:32pm |
So tried out the slick shift today , what a improvement in the gear shift far more accurate and easy to find gears . Just need to heat and bend gear stick a bit as it is just hitting the air con in 1st and 3rd. still has a bit of rattle but the turret is a little worn according to the garage so will replace that and I think the cheap gear knob I fitted might be part of the problem as well so will change these both to hopefully finally get rid of the gearstick vibrations.
24th Feb 2018 7:40pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
Seriously considering the slick shift. Is it not adjustable to not hit the aircon? Ray
24th Feb 2018 8:12pm |
Yes Ray it is supposedly the garage might not have adjusted quite right but will look at that when fit new turret and see if I can adjust before bending. Go for it Ray I don’t think you will be disappointed
24th Feb 2018 9:00pm |
Great news with the slick shift that your happy with it Clayton.
24th Feb 2018 11:23pm |
