Home > Puma (Tdci) > TDCi Mpg's |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4722 |
Last fill up returned 25.8 mpg.Family car so lots of local small trips mixed in with the longer stuff.Best ever was 29.7 on a long journey. 1982 88" 2.25 diesel
15th Jan 2009 8:10pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6308 |
I'll have a look tomorrow but this tank saw one trip of circa 200miles and the rest just local ie less than 10 miles and at the moment I know its very nearly 370 miles and the low level light hasn't yet come on.
17th Jan 2009 9:12pm |
well 400.7 miles before filling up again.
thats about 26.5 mpg what did I expect. its just a bit hard when the last car did <73 mpg on a tank (<60mpg on home made bio) |
26th Jan 2009 9:17pm |
SFDM Member Since: 08 Jan 2009 Location: South Bucks Posts: 6 |
Just filled up.....25.6mpg Ne nostra in fundamenta subeamus
27th Jan 2009 10:40pm |
Femund Member Since: 21 Apr 2008 Location: Norway Posts: 12 |
And the last car You had was comparable to the Defender (like; permanent 4WD, air drag like a brick, weight about 2 tonnes....)? Then I agree with You in this one But if Your last car was a Smart or a Toxxxa Aygo, then............ 08MY Defender 2.4 SE |
28th Jan 2009 7:48am |
well it had 4 wheels
a citreon picasso - was really making a comparison as much as to say it was a bit of a culture shock. |
28th Jan 2009 1:24pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
im shocked...it has to be a record 35.7mpg!!! 386miles with 49.06l required Mike
9th Feb 2009 11:17pm |
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 |
Still keeping track of mine - average 28.4 over the first 5,000 miles, which disappointingly is slightly down on the old Td5.
As mentioned elsewhere in this thread, strange for a vehicle with cleaner emissions AND a small claimed reduction in CO2/mile. What's also odd is that I get just over 30 on local/short trips, but drops to 25-27 on motorways, in spite of the 6th gear (generally around 70mph). The Td5 didn't suffer that way...maybe the non-perforated sump guard acted as an up-side-down aerofoil and cleaned the airflow under the chassis??? It seems a bit far-fetched... 1953 80 1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
10th Feb 2009 4:03pm |
Mike - meant to say - 35+ mpg??? Yours is a 110, isn't it? 1953 80
10th Feb 2009 4:05pm |
ah no - I must learn to read things properly!!! I should probably be happy with 28/29 out of a 110 1953 80
10th Feb 2009 4:07pm |
no its a 90 Mike |
Yes - realised my mistake as I pressed submit... 1953 80
10th Feb 2009 4:14pm |
No problem - if it helps the disco only did 29 - usually does 31 Mike
10th Feb 2009 4:22pm |
406 this time and the warning light came on. filled up at 420 which is about 28mpg.
15th Feb 2009 9:39pm |
