Home > Puma (Tdci) > TDCi Mpg's
Page 12 of 13 <123 ... 111213>
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I'm thinking it's something more like the variable veins on the turbo being stuck.
The car never feels like it's struggling, but to use that much more fuel (on the freeway) is just ridiculous.
[/img]
Post #14639 26th Aug 2009 6:10am
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
draymond wrote:
My fuel consumption seems to be backward?
I get 8.8l/100kms in the City (Sydney), and 11.2l/100kms on the freeway?
Has anyone else noticed something like this?
That is not bad consumption for city work.
The consumption you are getting for freeway driving is what I get in the city.
The only explanation I can give for the difference could be explained by the Defender's aerodynamic coefficient that approaches that of a streamlined brickwall. More effort required to push it through the air at higher speeds. Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #14648 26th Aug 2009 9:57am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
draymond wrote:
No, what i'm saying is, my car uses significantly more fuel on the Freeway, than it does driving to work everyday on the city streets.
Confused
Has any one else come across this?
Or know how it might be caused?
Yes - mine does a good 30mpg+ on minor roads, short stop-start journeys, and more like 28mpg on the motorway at a steady 70mph!
This is the opposite of what I expected too (especially with the 6th gear) - my V8 petrol was 17mpg on the local roads, 21mpg on the motorway.
The aerodynamics certainly come into it at higher speeds, but doesn't explain why my previous defender was the opposite? Both are high-geared at the top...
Post #14701 27th Aug 2009 10:01am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Mines the same on my regular run up to aberdeen at a steady and sedate 70-80mph i got 26mpg on the last two runs, but seem to get more running local around N yorks. I to thought aerodynamics and higher revs. Certainly uses more when the winds in the wrong direction, makes quite a difference over 320 miles.
Overall though I'm certainly getting more MPG than the D3, about the same on a long run but much more around town / local. But then again I didn't buy a Defender for fuel economy and count the cost of extra juice as part and parcel of my enjoyment. Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #14702 27th Aug 2009 10:15am
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
Mine's the same - getting near 30mpg from a 110 on backroads, local trips, etc and drops to 26 to 28 on long motorway journeys. The more m'way work, the worse the consumption.
I've started changing up at higher revs generally and this has improved the fuel consumption on short trips - maybe the combination of higher revs but less load on the engine reduces the work done by the turbo? My old Td5 was more economical on motorways, possibly because the engine was spinning faster and relying less on developing torque at lower revs to keep pushing through the air?
As a side issue, I found the pump I'd pulled up by in a very busy Shell station was delivering only their expensive 'I can't believe it's not liquid gold' diesel. Unable to reverse and find a standard diesel pump, I handed over the extra 7p per litre and gritted my teeth. Was it my imagination, or was the engine far more smooth, powerful and refined? Didn't quite get my 7% back in improved fuel consumption, but the driving experience almost made it worthwhile - anyone else used this fuel, either deliberately or by accident? Wink 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #15076 4th Sep 2009 10:19am
Rocket123
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Epsom Green
I'm inclined to agree that BP ultimate etc seem to make the engine quieter and feel more responsive, but this seems to make zero difference to the fuel consumption.
My XS DoubleCab has averaged 24.75 mpg over 13,000 miles. Best almost 30mpg (driving at less than 60mph), average 25 (70-80 on the motorway and driving normally without considering fuel consumption), and about 19-20 towing flatout (between 65-75mph 1.5 tonne trailer). see below
Post #15095 4th Sep 2009 2:46pm
mse
Shell V-power ive used and have to say it was good alround, but the cost i dont think warrants it on these cars Mike
Post #15099 4th Sep 2009 3:56pm
MK
@ top speed of 100km/h yielded 29.4 mpg. Over that (120 km/h), it goes down to 25.4 mpg. Puma 110" SW
Post #15300 9th Sep 2009 11:33pm
draymond
Took my car in for a 10,000km service yesterday.
Apparently there was a software update that has noticeably improved the mid-range.
Seems to pull much better from 80-120km/h (speedo indicated). Hopefully may improve freeway consumption.
Dave.
Post #15301 10th Sep 2009 1:05am
PumaGreg
United Kingdom 2013 Defender 90 Puma 2.2 SW Tamar Blue
Good to know that I'm not the only person that tracks my fuel con on an excel spreadsheet…………
Again, in agreement with the general view here - I get the good side of 30 mpg if I avoid the motorway, but typically 27 mpg with some motorway usage.
Like Ads90, the V8 50th I had previously was 17 ish mpg running around and 20 mpg on the motorway. Greg
Currently:
2013 90 2.2 Puma Base Station Wagon
1991 90 Tdi
2015 Discovery Sport 2.2
Post #15313 10th Sep 2009 11:53am
mse
30.1mpg - happy with that Mike
Post #15594 17th Sep 2009 11:01am
scatt
England 2008 Defender 110 Puma 2.4 DCPU Alpine White
Dave.
Ive been told by my local dealers that the software update has been put on hold because its causing more problems than its solving??
Oh, and regards fuel consumption im getting approx 25mpg on motorway runs! but i am running 35x12.50 mud terrains.
Post #15609 17th Sep 2009 8:49pm
MK
Really! I´ll leave mine as it is.
Remarkable mpg for those shoes.
MK Puma 110" SW
Post #15616 17th Sep 2009 11:20pm
spudfan
Ireland
Best I got with the Puma Tdci 110 is 30.45 mpg. on a recent holiday. Wife and two kids with enough cargo to fill an aircraft carrier. (three females, enough said). Funnily enough this was not cruising in sixth gear but on minor roads mainly in 4th gear. Does not do near as well when cruising at 100 kmh(60 mph). 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #15641 18th Sep 2009 3:28pm
Caterham
60mph is too quick for good economy - try low 50's if you want decent mpg.....
talking of which my mpg seems to have dropped off. I'm struggling at the moment get much over 400miles before the orange light comes on. ok so I might be going a little quicker but to my mind it's dropped off more than the slight increase in speed I might now be undertaking. My obvious thought goes to the MAF sensor but just wondering if there's any other tell tales when the MAF goes up the shoot?
Post #505600 17th Feb 2016 8:24pm
