Home > Maintenance & Modifications > Recall Number: P022 Park Brake Oil Contamination
Page 1 of 7 1234567>
Lorryman100
Recall Notice: P022 Park Brake Oil Contamination
Date of Issue: 22nd February 2011
VIN Range: LD066843 � LD071690 (CKD) LD730411 � LD823248
A concern has been identified with the park brake fitted to 2007-2011 Defender vehicles. Any vehicle repaired under Recall Action P019 prior to the revised repair procedure identified in bulletin P019v4 must be recalled and repaired under this campaign. The shoes of the parking brake could be contaminated with oil which has leaked from the rear of the transfer box. Where oil from the transfer box has impregnated the park brake shoes, the park brake may not hold the vehicle when the park brake lever is applied and the vehicle may instantaneously roll. Transfer box oil contamination of the park brake shoes and brake drum leads to a loss of friction between the brake shoe lining and the brake drum friction surface such that the park brake drum when engaged will not hold the vehicle stationary on a gradient.
Action to be taken:
Land Rover has taken the decision to recall affected vehicles to remove the output shaft flange, clean the splines, apply Loctite 648 and where necessary and the brake shoes will also be replaced.
Post #60898 24th Feb 2011 1:09pm
MK
Was not this announced last year? Sounds familiar Question Puma 110" SW
Post #60902 24th Feb 2011 1:29pm
Lorryman100
Whistle
Post #60905 24th Feb 2011 1:34pm
BigRuss
Cheers lorryman Russell
2011MY 110 XS USW Black
Post #60909 24th Feb 2011 2:03pm
MK
Embarassed Puma 110" SW
Post #60910 24th Feb 2011 2:04pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Does this means that, as my vehicle was bought last April, I sholud not call the dealers atention to it, in case they forgot ? In my 110 this is solved ? Question
Or mine is included ? it LD786 and something ... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #60916 24th Feb 2011 3:58pm
RED-DOT
I had this recall done last May and my 2007 Defender got an advisory 8 weeks later for MOT handbrake efficiency by the same dealer...... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #60919 24th Feb 2011 4:39pm
BigMike
no, should be fine. P019 only affected early vehicles.
Post #60924 24th Feb 2011 5:15pm
Lorryman100
For those who are not aware of Topix and wish to check if their vehicle has been identified for any recall actions I've done a little how to.
First go to: http://topix.landrover.jlrext.com/topix/vehicle/lookupForm
and register with the site.
then once registered enter your Landy's vin number:
this then brings up the screen on your Landy, you can access Bulletins etc, but will have to pay a subscription to view them Big Cry
If you look at the red circled text in the top right corner you will see the recall notice and it is applicable to my Landy. And any other Field service actions will be listed here. Apologies if I'm teaching you to suck eggs, thought it might help someone. Thumbs Up
Post #61051 25th Feb 2011 12:41pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Amazing, this recall is for UK only for now...
If I set my country to France, no recall. Then if I change to UK, bingo!
Outstanding field service actions:
P022 - PARK BRAKE OIL CONTAMINATION
And that's for the same VIN... Big Cry
So if you live in France, better park in gear Rolling with laughter
Post #61060 25th Feb 2011 1:12pm
wurzell
hi Very Happy many thanks lorryman100 for posting this up i spoke to my local dealer yesterday and its booked in to have that work done ,i assumed that land rover would of written to everybody it affected but not received any thing anyone else had a letter many thanks again Thumbs Up
Post #61187 26th Feb 2011 1:58pm
AJS4X4
We did our own repair, took about 10 mins.
Andy.
Post #61189 26th Feb 2011 3:06pm
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I haven't checked topix but I was informed by my service advisor to bring my 110 in to have recall fixed on my car and I live in united arab emirates. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #61204 26th Feb 2011 8:12pm
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
It's funny, mine also says "no problem" if i register as South Africa, but if i go back and change the setting to UK it says i need to repair it... www.ralton.co.za
Post #61307 27th Feb 2011 6:17pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
My Defender is of 27 April 2010...I live in Italy ,and I have this Recall
Post #63175 10th Mar 2011 7:49pm
