Home > Camping, Caravanning and Holidays > Sankey MkII Trailer - My refurbishment starts
Page 3 of 9 <123456789>
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Nice solution. I just need to get a day off work and drag mine down to my mates garage. He stops opening up on Saturdays during the summer to go down to his caravan.
Paint wise, a sankey tub is never going to look a million dollars, as nothing is truly flat/straight. I suspect gloss black will probably exaggerate the issue. That said though, because they are an ex-military trailer you'll get away with Stevie Wonder painting it. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #518317 27th Mar 2016 9:07pm
Stacey007
No design as yet. Not 100% I understand, as removing the carry rings I thought simply allows for alloys to be fitted?
My savings on me painting it and sanding it etc may go towards 2 sawtooth alloys and spacers to match my car Smile
I have two continental tyres to match the car ready Smile
Post #518319 27th Mar 2016 9:09pm
xpertoftheseas
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Aintree Green
Yep - I thought the same. I am waiting for my Sankey to come back and then I will test fit the SVX alloys. Will let you know.
If the SVX alloys fit then the saw tooths will also. If not then I will design and have some custom spacers made that will have the bearing caps built in. My 10th Land Rover, but my first Defender.
Post #518337 27th Mar 2016 10:15pm
keith
Nice job Stacey . Keep up the good work
I'm off with my troop on Wed to the islands .
Post #518371 28th Mar 2016 8:34am
Stacey007
So this evening after borowing my dads angle grinder, I tried to remove the carrying rings from one of the hubs.. I've read with most alloys these will not fit with these fitted,
Much harder than I though, but it came off. However leaving it like this will allow grit and road crud to get in when I refit. What could I use to cover this?
Does it need a metal plate welded over it or anything else?
Only done one, so will wait before I do the other to see this can be sorted.
Post #519301 30th Mar 2016 7:33pm
xpertoftheseas
Yes, you will need need a cap. I am making two for my mk3. If you could do me a favour and measure the PCD of the cap bolts (waiting for my trailer to come back) and let me know and I will whip up the drawings and will send to you. My 10th Land Rover, but my first Defender.
Post #519320 30th Mar 2016 8:08pm
Stacey007
Sorry was busy all evening and just been out,
No power in the garage the trailers in so phone flash as torch..
^this shows the tape in the wrong place the measurements below are right the picture was just to show..
I measured 16cm across from one side to the other and center of one bolt to center of the other 9.5cm
does this help?
Post #519785 31st Mar 2016 9:18pm
xpertoftheseas
Thanks, but I believe you are showing the PCD of the main wheel nuts. To make the cap I need the PCD of the centre cap bolts (the 6 bolts). If you measure one bolt centre to opposite bolt centre, we can work out the PCD. My 10th Land Rover, but my first Defender.
Post #519800 31st Mar 2016 9:49pm
Stacey007
^ Your right...
Sorry will try again this weekend. Is this what you need but for the hub cap I cut the ring off?
Post #519839 1st Apr 2016 7:06am
xpertoftheseas
This is exactly what I need bit for the hub bolts yes. If you could also measure the stud diameter and also the hole diameter in the middle I can design the cap from these dimensions. Thanks Stacey007. My 10th Land Rover, but my first Defender.
Post #519847 1st Apr 2016 7:43am
Stacey007
Does this help?
center of bolt to center 5cm
across the center to edge of hole on each side 11cm
Post #520111 1st Apr 2016 7:44pm
xpertoftheseas
Perfect!! Will work out the dims and draw it up. Will post when done ...
Thanks again... My 10th Land Rover, but my first Defender.
Post #520124 1st Apr 2016 8:34pm
keith
does this help?
Oy Stacey , you got some seriously hairy hands there Shocked
Think you need your nails dooing Laughing
Nice work .
Post #520139 1st Apr 2016 9:19pm
xpertoftheseas
Bearing Cap
I put this together tonight. However, I have a concern about the protrusion of the cap flange allowing the wheel to press again the bearing cap and not the face of the hub. You can get around this by building the cap into a spacer (essentially a wheel spacer with solid centre. I will not be able to confirm until I get my trailer back and I can measure the hub. The wheel must mate with the wheel hub therefore forcing the fact that an adapter may be required if the bearing cap flange protrudes over the face of the wheel hub.
If you need the drawing in a higher resolution, PM me and I will send you the PDF). However, I would wait until I have got the measurements of the hub so I can confirm that wheel will sit correctly. Better get this right first time Thumbs Up My 10th Land Rover, but my first Defender.
Post #520164 1st Apr 2016 11:42pm
Stacey007
Had a little bit of sankey time today....
Not much as gardening took over...
Anyway removed a wheel and went from
to this which I think is looking a bit better.
Still lots more to do and more underseal but I wanted to paint something !
Post #520656 3rd Apr 2016 8:01pm
