Home > Camping, Caravanning and Holidays > Sankey MkII Trailer - My refurbishment starts
Page 9 of 9 <123456789
Stacey007
Ok relatively quick job that fill in the blanks in arches.
It does look better 👍
Post #774951 25th May 2019 9:59pm
Sulisuli
Tidy job, looks very smart well done Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #774954 25th May 2019 10:25pm
Stacey007
Ok few more things...maybe not 'needed'
Swapped the non hub centric spacers for hubcentric ones...
Also collected the wood for my top to make. Had great comments from the people at builders yard👍
Trial fit.
Post #775604 30th May 2019 7:33pm
Stacey007
Ok so test fit after painting, couple of hinges to try the opening and quite happy with results
Post #775967 2nd Jun 2019 9:10pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Looking good. You must be very happy with how it's turning out.
Post #775979 2nd Jun 2019 9:36pm
mikerajjers
Slovakia 2000 Defender 90 Td5 SW Cairns Blue
Stacey007 wrote:
Thon
I have the bits ready to fit (actually arrived Friday when back from work) however needed to collect it Saturday morning and no time to sort.
Your right the MoD would secure the Nato hitch directly to the cross member using the 4 bolts.
I have this
and hopefully when fitted I can do this...
Which brings it almost in line with the 4 bolts on the cross member plus I can put my normal bar back on Smile
This however if used on highest setting also means either a higher spare wheel carrier or as the forum member whose pictures these are use it one down. Still works and sits level.
(pics of hitch taken from a forum member offering me advice) Thumbs Up
Hello, I am looking to use a similar set up to you. Do you know which length of drop plate you used? There seem to be a number of length available online. Thanks
Post #874168 22nd Dec 2020 2:01pm
NC500
Hello - fascinating and very helpful thread, thank you. I have just purchased a MK2 Sankey and have recently started a refurbishment along the same lines as yours. However, my VIN plate is very badly abused (see photo). I can make out the stamped details and want to renew the plate but I need a clear photo of a good VIN plate to use as a template. Could you send me by email a photo of yours that I could use as a template?? Thanks!!
Post #1058782 28th Jan 2025 10:20am
