Home > Camping, Caravanning and Holidays > Sankey MkII Trailer - My refurbishment starts
Page 8 of 9 <123456789>
When I did mine, I used some plastic arches that were intended for a Transit tipper:
There's more details in my trailer build thread here: https://www.defender2.net/forum/post264460.html#264460 Darren
Post #772965 13th May 2019 7:05pm
Landy Andy of this parish fitted Defender arches to his, but he made a complete overlay for each trailer side that was profiled to suit:
 Darren
Post #772966 13th May 2019 7:06pm
Stacey007
Ok so as I had the arches, I've sprayed them and fitted one with 4 bolts / washers for now. Seem secure
Should this work ok?
Post #773405 16th May 2019 8:00pm
Yeah, I guess... Confused Darren
Post #773409 16th May 2019 8:09pm
Stacey007
I've bought some steel to see if I can fill in the gaps... ^ I cannot weld so need to find some way.
Don't think the overall look it too bad.
Still need to make a cover that opens....
Post #774602 23rd May 2019 8:45pm
landy andy
I just bonded on alli sheet that I had cut with jigsaw. I cut so had extra material at wheel arches, then cut that so I could bend tabs inside to hold the arches on.
Post #774603 23rd May 2019 8:52pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Landy Andy, I like the way you've added material underneath as well. Makes it all fit together nicely
I had my tame welder stitch in some corner fillets
At some point I'll get round to adding the arches to mine Whistle 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #774649 24th May 2019 8:05am
landy andy
Thanks.
Was just alli sheet cut with jig/circ saw and bonded on with Pu adhesive
Post #774654 24th May 2019 8:21am
Rosco
Ahh that image makes it clearer. You've over skinned the whole side of the tub? I had wondered how you'd got such a smooth looking finish Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
Post #774665 24th May 2019 9:11am
Stacey007
I'm with you also, I could not see the joins...
Nice job, was it expensive for the sheet?
As for the sides cut out I will have a go.... not sure how to fix them..
Post #774685 24th May 2019 11:49am
landy andy
Really cheap, and really easy.
Was about 15 each side. Pack of jiga blades, and some time with a file.
Used the wheel arch off a defender as the guide for cut out, then added about an inch onto that. I then cut it out and left the extra inch sections where the fixing studs for the arches were, and then bent them inward, so I could easy fix wheel arches.
I used the holes where the tie down cleats are so I could dry fit and use for marking out. Then when ready glued it on with tigerseal. Then bolted through the cleats, and where the side reflectors are.
Post #774698 24th May 2019 1:18pm
Stacey007
Great Thumbs Up
Where did you get the alloy sheet from, and what thickness?
I doubt I can do this for now but worth looking into. Cheers
Post #774703 24th May 2019 1:50pm
miker
Having looked through this thread, I feel like the Sankey Facebook group is mostly filled with def2 members!
Post #774723 24th May 2019 3:38pm
Stacey007
Ok so back from work and had a go at making a cover out of some steel and brackets.
This should make the corners better with the arches on.
3 more to make and spray..
Post #774758 24th May 2019 7:44pm
keith
Great work on the trailer. Looking forward to the finish.
Keith
Post #774761 24th May 2019 7:58pm
