![]() | Home > Camping, Caravanning and Holidays > Sankey MkII Trailer - My refurbishment starts |
xpertoftheseas Member Since: 05 Jan 2016 Location: Salisbury, Wilts Posts: 164 ![]() ![]() ![]() |
If the drum is old and worn heavily, the lip created on the drum could prevent the shoes from passing as you pull the drum off. If there is an adjuster, back it off as much as possible. If there isn't one, make sure the master cylinder has no pressure on it at all and try to pull it back as much as possible, as this will pull the slave cylinder back in as far as possible, hopefully bringing the shoes with it.
Failing that, a piece of 2x4 and a 10lb tapometer usually does the trick. Nice paint job... looks much better. My 10th Land Rover, but my first Defender. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
Had a spare hour this evening in between making packed lunches for the kids tomorrow and cooking dinner...
Watched a few you tube clips in preparation. Wheel wire brushed, sanded down, cleaned and then ready to spray. Started with this. ![]() Click image to enlarge then primer ![]() Click image to enlarge ![]() Click image to enlarge then 1st coat black ![]() Click image to enlarge 2nd coat. ![]() Click image to enlarge I will give it a 3rd coat tomorrow but I'm happy with the results given never ever done this before. I have new tyres to go on also. My plan maybe to fit alloys but thought I might as well make these smart anyway. Given less than an hour for the wheel pleased with that. |
OK, Have managed a little time in the garage, in between back from a lovely holiday and starting back at work
Decided for now not to go the alloy wheel route as my new moto Keep the Sankey simple however I wanted to sort the hubs in case I do in the future. So thought about this... and came up with a solution (I think) 5mm steel plate fitted the gap I cut off. ![]() Click image to enlarge ![]() Click image to enlarge Then as I cannot weld needed an option to hold it in place, so interweb came in handy. Special glue ![]() ![]() Click image to enlarge ![]() Click image to enlarge Wanted to have a quick look what it looked like so loosely fitted the wheel. I'm pleased with this ![]() ![]() Click image to enlarge Then a little bit more painting and sanding the tub down... ooh and I've taken the reflectors off to sand behind. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Have to say I'm quite enjoying this ![]() |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1862 ![]() ![]() ![]() |
Nice progress, but aren't your wheel nuts on backwards? 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Quite possibly
![]() It back off now ready for the new tyre. Good spot ![]() |
Not much time spent on the Sankey, got some projects on in the garden requiring my time
![]() Anyway managed to get one of the wheels fitted with a tyre matching my truck, bit disappointed even though its a trailer wheel they scuffed the edge a bit. Looks much better though given I sprayed it. ![]() Click image to enlarge Then managed to angle grind the other carrier off the hub on the other side, messy job but I've done the other side and it looks ok so will be ready if I do fit alloys. ![]() Click image to enlarge ![]() Click image to enlarge plodding on ![]() |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
Good work , looks lovely. Don't forget your nuts
I've swapped my nuts round the correct way
![]() ![]() I'm still worried about having ago at painting (spraying) myself.... never sprayed anything before the steel wheels on this sankey. I guess nothing to lose, I can always get it blasted and someone else do it.... |
Does it have to be sprayed ? I s 2 or 3 coats by roller not good enough ? It's a thicker , neater more robust finish in my view.
Hello
Good call, I'm not sure... What paint would you recommend? would you spay primer it first though? Cheers |
Very little to update,
Got the other Tyre swapped for a Continental matching the car, was funny as I left it with the tyre place and collected it later. Came back and a different guy there, I said " I come to collect the trailer wheel'. Off they go looking for it and look confused then I spot it leaning on the wall. So said 'thats it over there' he looked at it and looked at me, A Trailer? he said... Yes its an ex army one, not a normal garden tip one ![]() So tonight job fit the 5mm plate on the hub. The tomorrow spray it and fit the wheel center. ![]() Click image to enlarge |
OK little bit of painting today after much sanding.
Its not perfect but its in keeping with the trailer and better (for me than the Nato green) Took the front and rear reflectors off, that was fun they didn't want to budge..... ![]() Click image to enlarge ![]() Click image to enlarge Then finished the hub for the other side, sprayed and center cap on (on and messing about with a snow cowl..) ![]() Click image to enlarge Might have a go at roller painting the inside of the tub soon as that will be a good indication to if I should have a go at spraying the outside or rolling it... |
OK in between rain showers and I really need power (lights in my garage) even during the day its gone so grey its hard to see.
Tried spraying the rear tailgate on the inside. ![]() Click image to enlarge Not sure I'm happy spraying and also I think the finish is Harder (is feels more robust) painted so think I'm going to try and roller paint with a small roller brush. I've started doing the trims and awkward bits by hand. ![]() Click image to enlarge ![]() Click image to enlarge Then I fitted the center cap to the other wheel, looking smart now with normal tyre and newly sprayed wheel. ![]() Click image to enlarge Had a quick practice hand painted the front square to see how it looks, Actually looks ok but think a roller is the way forward and a few coats. ![]() Click image to enlarge need to think maybe about mudflaps / guards as the wheels do stick out a bit (std steels) no spacers. |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 ![]() ![]() |
what primer and paint have you used? I used bog standard Halfords primer and the rust started to come thru after a while. I guess if you are overlaying this with rust treating paint like hammerite etc should be ok. I'm onto my tub now. 2-3 coats of zinc oxide and first coat of satin black Hammerite but painting it on with brush. Doesn't go on terribly well with first coat but hoping subsequent coats apply better. Have got a small roller as well to try applying to larger flat areas.
