Home > Maintenance & Modifications > Replacement headlight harness - Highly recommended
Page 10 of 11 <123 ... 91011>
Cupboard
Tiger is correct in that when you've got the headlamps on and you use the flash, you get both the main and dipped on.
Does that matter though? It's still less than the fuse rating and it's not for very long.
Post #411238 26th Mar 2015 9:50pm
Dave k
bob neville wrote:
Not sure if this has been mentioned before, apologies if it has.
I have been using the Red Bison loom for 3 months without any issues.
Monday, no headlights at all, not even when flashed Shocked
Tuesday they were working again without any intervention on my part.
Today, they stopped again. Just checked the fuses and relays under the steering wheel, all OK.
Had a play with the two relays in the RB loom and they had both come lose, enough to stop the headlights working. Pushed them fully home and I have lights again. I will have a good look this evening to see what is going on.
Probably just need the female recptors closing a bit to get a better fit.
Bob
Just a similar problem with the main fuse.
Tweeked the connecters, & have moved the fuseholder to a better location. Ex RN 110 Station Wagon
Never Raced or Rallyed
Post #421043 4th May 2015 11:44am
Eduardo
Bob, Dave
I had a similar problem in my trip to Patagonia. Relay holder went loose in the contact area with the realy and burn all my spares relays in a quite isolated area Evil or Very Mad .
Finally I took out the relay holder and made a direct connection (so I can turn on the ligths without to tur on the car).
It works like that since February without any trouble (just remember to turn off the ligths).
Will be a good idea to replace the relay holder for one of a better quality and rewiring the ligths.
Cheers! Eduardo
Post #421115 4th May 2015 6:43pm
Dave k
Mine has started playing up again.
Could just be a bad earth.
I'm going to take it off & check all the connections. Big Cry
Update,
Fault found to be broken spade terminal!
Have remade some of the connections, & intend to fit a better fuse box Rolling Eyes Ex RN 110 Station Wagon
Post #423287 13th May 2015 8:12pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Fitted a Landreiziger kit today that I've had for ages, all went well, very easy to fit, just a couple of questions...
I guess as previously stated, there is now no dip before headlights, there's only dipped headlights with this kit when the ignition is off? The indicator stalk supplied is exactly the same as standard and makes no difference.
Also, a couple of hours after locking up the vehicle - the alarm is going off !!
Is there any obvious reason for this? Have I done something wrong or has anyone else had a problem like this?
Post #435193 1st Jul 2015 11:21pm
munch90
the switch is the same , no need to change it unless there is a problem with the old one
you should have
ign off , just park/sidelights
ign on , sidelights , dipped headlights , full beam headlights
no dim dip as you need to disconnect it ( if its fitted , not all defenders had it )
alarm going off , not sure about that one , really its retrace your steps and check if you knocked something
Post #435219 2nd Jul 2015 7:42am
Lambley
Cheers Munch,
I've got as follows....
Ignition off with light switch in position 1 or 2 - small sidelights only
Ignition on - with light switch in position 1 - small sidelights and dipped headlights
Ignition on - with light switch in position 2 - small sidelights and dipped headlights
So, in position 1 or 2 on the stalk makes no difference - is that correct? It used to go from sidelights in position 1, then when pressed to position 2 for dipped headlights?
Also, is this ok for an MOT - is there not a need for sidelights only with ignition on when doing an MOT?
I'll go over the wiring again today and check there's no way I've dome anything wrong or it's grounding to earth somewhere, just wondered if anyone has had the same issue?
Post #435220 2nd Jul 2015 7:54am
munch90
sounds like you need to disconnect dim dip resister
this bit is wrong from your post
" Ignition on - with light switch in position 1 - small sidelights and dipped headlights " ( should be sidelights only )
as said disconnect dim dip resister , easy to do and not something you done wrong as said some have dim dip system fitted some don't
you don't need dim dip for mot just sides / dipped / full
Post #435222 2nd Jul 2015 8:03am
Mo Murphy
What you have is correct Lambley, the headlights are inhibited with the ignition off. This so you don't leave your lights on and run the battery flat.
50 Shades of Pennine Grey
Post #435481 3rd Jul 2015 9:37am
munch90
Yes no headlights with ign off , but he has headlignts and sidelights with ign on and 1st click of switch which isnt right , should be sidelights only
Post #435484 3rd Jul 2015 9:47am
Cupboard
Has anyone put a flywheel diode on the relays in the kit?
When I change from full beam to dipped, or from dipped to off the indicator (<and>) warning lights briefly come on and I was wondering if that was from the relay coils.
Post #435516 3rd Jul 2015 12:40pm
munch90
you can buy relays with diode built in
not sure if that's your problem, what warning lights ?
where is feed for relays taken from ?
Post #435517 3rd Jul 2015 12:48pm
Mo Murphy
Ah yes, my mistake munch, I misread it. Time to bridge the dim dip relay.
Post #435598 3rd Jul 2015 7:07pm
Lambley
Thanks munch and mo, I've read up on removing and bridging the dim dip relay so I'll give that a go over the weekend, how is it that one small job leads to 3 others?!! Confused
As for the alarm going off - that's sorted, after it went off randomly a few times I sat in the back for a few mins and spotted a huge spider living beside the interior movement sensor, it's not happened since the spider was relocated Thumbs Up
Post #435659 4th Jul 2015 12:17am
munch90
think the quicker option is just unplug the resister under the wing
Post #435677 4th Jul 2015 7:33am
