Home > Maintenance & Modifications > Puma Gearstick rattle / vibration cure guide (with photos) |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2751 |
Did the same today. Works like a charm, although I used cable ties which means no messy glues/silicones
See below: Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
29th Mar 2014 8:38pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
30th Mar 2014 3:34pm |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 |
Thanks for the handy tip should be made a sticky
9th Apr 2014 6:53pm |
Already is a sticky Cheers, David
9th Apr 2014 8:41pm |
Yeah, I think I didn't realise how much it was subtly annoying me! Cheers, David
9th Apr 2014 10:06pm |
Harry van Wyk Member Since: 28 Mar 2014 Location: Cape Town Posts: 2 |
Got the same problem and dealers cannot fix it. Took it back once and still the same rattle. Will now fix it myself. Thanks a lot.
10th Apr 2014 5:40am |
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 |
I can see why you did this, but I'm being a bit thick as to how - did you leave the cable ties undone as per your photo, acting as a buffer between the plastic and the metal? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
28th Feb 2015 5:04am |
All sorted now - obvious what the problem is once you take the lever off. Fixed with cable ties as per David' photo. A genuine 2 minute job!
15th Mar 2015 3:23am |
Coolcamper55 Member Since: 22 Apr 2010 Location: Inverclyde Posts: 45 |
Now I need to find something to do with my left hand other than holding the gear stick. Thanks Tommy
110 XS TDCi |
18th Mar 2015 9:08pm |
wmca Member Since: 15 May 2013 Location: Brisbane Posts: 26 |
Well, this was worthwhile, if not one of the best and easiest mods, thanks for that sitting in a vehicle for 600-800 kicks a day its a god send. Bill WMcA Brisbane Australia Defender 2.4 Puma 2009 “Airbags! The other vehicle is my crumple zone!" |
20th Mar 2015 11:00pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
what are the symptoms of this problem? i have a high pitch metallic rattle coming from somewhere. could this be the weights on the gear stick?
23rd Jul 2015 11:32am |
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 209 |
Cheers Steve and David, did mine today as it had driven me mad on a trip back from Andorra to Blighty , used glue and cable ties, trimmed up, all is quiet now.
Getting the gaiter back on proved irksome at first as it was tight and I was worried I might split it. So I then extended the gaiter fully out and inserted the bottom half of the gearstick front end and rotated clockwise thro 360 degrees, it slid straight in, then engaged the gearstick into place making sure it had located properly......job done |
28th Sep 2015 7:40pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20299 |
Mines still working perfect.
Reason I didn't go for ties was because it looks a little bodge like, even though it will work perfectly of course. A good quality superglue will work perfectly and permanently and you'd never even notice it was done. If you've done both though it's belt and braces and you'll never have a problem with it again. |
28th Sep 2015 7:54pm |
enfield_dinosaur Member Since: 14 Jun 2015 Location: Tertius orbis Posts: 120 |
Fantastic guide! The operation has been successful.
But, how, how on Earth goes the gaiter back where it's supposed to be? Is there a trick to it? |
28th Oct 2015 5:40pm |
