Home > Maintenance & Modifications > Puma Gearstick rattle / vibration cure guide (with photos)
Page 2 of 6 <123456>
Cheshire110
Did the same today. Works like a charm, although I used cable ties which means no messy glues/silicones
See below:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers, David
Post #320111 29th Mar 2014 9:38pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Thumbs Up Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #320257 30th Mar 2014 4:34pm
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Thanks for the handy tip should be made a sticky
Post #322734 9th Apr 2014 7:53pm
Cheshire110
Already is a sticky Cheers, David
Post #322769 9th Apr 2014 9:41pm
Tis' indeed, thanks to Martin.
Certainly works, not a peep of noise from mine any more.
Makes driving in higher gears more of a pleasure.
Post #322790 9th Apr 2014 10:59pm
Cheshire110
Yeah, I think I didn't realise how much it was subtly annoying me! Cheers, David
Post #322793 9th Apr 2014 11:06pm
Harry van Wyk
South Africa 2012 Defender 110 Puma 2.2 SW Alpine White
Got the same problem and dealers cannot fix it. Took it back once and still the same rattle. Will now fix it myself. Thanks a lot. Thumbs Up
Post #322809 10th Apr 2014 6:40am
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
See below:
I can see why you did this, but I'm being a bit thick as to how - did you leave the cable ties undone as per your photo, acting as a buffer between the plastic and the metal?
Post #402960 28th Feb 2015 6:04am
AndyTunn
All sorted now - obvious what the problem is once you take the lever off. Fixed with cable ties as per David' photo. A genuine 2 minute job! Thumbs Up
Post #407647 15th Mar 2015 4:23am
Coolcamper55
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Now I need to find something to do with my left hand other than holding the gear stick. Thanks Tommy
110 XS TDCi
Post #408830 18th Mar 2015 10:08pm
wmca
Australia 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Gear lever rattle
AndyTunn wrote:
All sorted now - obvious what the problem is once you take the lever off. Fixed with tie-wraps as per David' photo. A genuine 2 minute job! Thumbs Up
Well, this was worthwhile, if not one of the best and easiest mods, thanks for that sitting in a vehicle for 600-800 kicks a day its a god send.
Bill WMcA Brisbane Australia
Defender 2.4 Puma 2009
“Airbags! The other vehicle is my crumple zone!"
Post #409424 21st Mar 2015 12:00am
Roy5695
what are the symptoms of this problem? i have a high pitch metallic rattle coming from somewhere. could this be the weights on the gear stick?
Post #439866 23rd Jul 2015 12:32pm
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
Cheers Steve and David, did mine today as it had driven me mad on a trip back from Andorra to Blighty , used glue and cable ties, trimmed up, all is quiet now.
Getting the gaiter back on proved irksome at first as it was tight and I was worried I might split it. Idea So I then extended the gaiter fully out and inserted the bottom half of the gearstick front end and rotated clockwise thro 360 degrees, it slid straight in, then engaged the gearstick into place making sure it had located properly......job done Thumbs Up
Post #458817 28th Sep 2015 8:40pm
Thumbs Up Mines still working perfect.
Reason I didn't go for ties was because it looks a little bodge like, even though it will work perfectly of course.
A good quality superglue will work perfectly and permanently and you'd never even notice it was done.
If you've done both though it's belt and braces and you'll never have a problem with it again.
Post #458827 28th Sep 2015 8:54pm
enfield_dinosaur
2007 Defender 110 Puma 2.4 SW Java Black
Fantastic guide! The operation has been successful.
But, how, how on Earth goes the gaiter back where it's supposed to be?
Is there a trick to it?
Post #467348 28th Oct 2015 6:40pm
