![]() | Home > Maintenance & Modifications > Puma Gearstick rattle / vibration cure guide (with photos) |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2770 ![]() ![]() |
Did the same today. Works like a charm, although I used cable ties which means no messy glues/silicones
See below: ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
![]() ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 ![]() ![]() ![]() |
Thanks for the handy tip should be made a sticky
Already is a sticky Cheers, David
Yeah, I think I didn't realise how much it was subtly annoying me! Cheers, David
Harry van Wyk Member Since: 28 Mar 2014 Location: Cape Town Posts: 2 ![]() ![]() ![]() |
Got the same problem and dealers cannot fix it. Took it back once and still the same rattle. Will now fix it myself. Thanks a lot.
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 ![]() ![]() ![]() |
I can see why you did this, but I'm being a bit thick as to how - did you leave the cable ties undone as per your photo, acting as a buffer between the plastic and the metal? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
All sorted now - obvious what the problem is once you take the lever off. Fixed with cable ties as per David' photo. A genuine 2 minute job!
![]() Last edited by AndyTunn on 21st Mar 2015 11:42pm. Edited 1 time in total |
Coolcamper55 Member Since: 22 Apr 2010 Location: Inverclyde Posts: 45 ![]() ![]() ![]() |
Now I need to find something to do with my left hand other than holding the gear stick. Thanks Tommy
110 XS TDCi |
wmca Member Since: 15 May 2013 Location: Brisbane Posts: 26 ![]() ![]() ![]() |
Well, this was worthwhile, if not one of the best and easiest mods, thanks for that sitting in a vehicle for 600-800 kicks a day its a god send. Bill WMcA Brisbane Australia Defender 2.4 Puma 2009 “Airbags! The other vehicle is my crumple zone!" |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
what are the symptoms of this problem? i have a high pitch metallic rattle coming from somewhere. could this be the weights on the gear stick?
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
Cheers Steve and David, did mine today as it had driven me mad on a trip back from Andorra to Blighty , used glue and cable ties, trimmed up, all is quiet now.
Getting the gaiter back on proved irksome at first as it was tight and I was worried I might split it. ![]() ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20651 ![]() ![]() |
![]() Reason I didn't go for ties was because it looks a little bodge like, even though it will work perfectly of course. A good quality superglue will work perfectly and permanently and you'd never even notice it was done. If you've done both though it's belt and braces and you'll never have a problem with it again. |
enfield_dinosaur Member Since: 14 Jun 2015 Location: Tertius orbis Posts: 120 ![]() ![]() |
Fantastic guide! The operation has been successful.
But, how, how on Earth goes the gaiter back where it's supposed to be? Is there a trick to it? |
