![]() | Home > Puma (Tdci) > Puma fuel bleeding pump |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Yes it was a standard item, however the supplier found them in a box of odds and sods so could not tell me where they got them or what they are called. I have posted pictures on the D3 site as some of the guys over there have 'contacts' and there is more of them. http://www.disco3.co.uk/forum/post345511.html#345511 I will continue to see if I can track them down. Basically all you need is a male end that is about 9.6 to 9.9 Ø and about 20 to 30 long. |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Now to obtain the difficult bits as there is currently no stock in town of clear plastic tube or the rubber pump
![]() Wow - you must be pretty remote then ![]() Series III 1973 - going strong |
So your nearest Land Rover service centre isn't 1100km away - 680km is dirt track and there are numerous water crossings?
![]() 110 300Tdi ![]() LROCV ::: AULRO.com |
If a male is so thin and as short as 20 - 30 he is probably Chinese or Indian
SteveNorman Member Since: 16 Sep 2008 Location: Somerset Posts: 18 ![]() ![]() |
Hi Andrew,
I think that the TD5 discovery fuel connection is the same. I will check out the dimensions. I keep the short pipe (which would have both male & female connections on it), which was used on the recall on discovery tank pipes where they rubbed through. These are quite cheap & if the same dimensions would be very easy to use. I'll post back ASAP regards Steve |
No the TD5 connections are 8mm, so no good.
Regards Steve |
Are there any other connections the same as that on the vehicle?
The price from Landrover for the fuel line £26+vat for the bit between the filter & the fuel cooler, this seems to have both male & female connections on it. The fuel line from tank to filter is only about £15+vat, but am unsure of the connections at the tank end. HTH Regards Steve |
how did you manage to go through so many filters already
Managed to score a boat tank from my brother whos said it was leaking - only found a dodgy top gasket
![]() Anyway, machined a fitting as per previose post and now have a fuel bleeder just in case. ![]() ![]() Click image to enlarge ![]() Click image to enlarge Puma 110 - gone Series III 1973 - going strong |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
that first photo of the dodgy looking fuel....
its not bio diesel is it? how did it get so contaminated? |
That diesel came from my company Toyota diesel and was used to clean some dirty engine bits.
Cheapest engine cleaner in the world. (company diesel card) ![]() I tested the pump in the jar before I cleaned the bits in the jar. Still need to test the pump on the Puma but the measurement is exact to the drawing so I am not in a rush to test the contraption as yet. Puma 110 - gone Series III 1973 - going strong |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
is someone so gentle to convert measure in metric unit??
![]() ![]() Defender 110 Td4 SE MY 09 |
I bought it from a diesel injection workshop for 22,00€ (build from DEPLHI).....
Matteo, 1 pollice (1") = 25.4mm ma il disegno è già in mm............................ The quotes are still in metric Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
