Home > Puma (Tdci) > Puma fuel bleeding pump
Page 5 of 10 <12345678910>
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
I know it's an old thread but I have just noticed lazer tools seem to do a tool which is for Ford vehicles and the Freelander.....
Now as we have a Ford engine in the Defender I wonder if it will fit....
Jonno
Post #364886 16th Oct 2014 10:08am
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
It comes with the correct size fittings so it should. Still expensive for what it is.
Post #365024 16th Oct 2014 6:32pm
AlanH
Australia
I've changed my fuel filter twice now and heeded the advice of a local independent who told me to make sure that when filling the filter to make sure that everything is totally clean so nothing gets in to the system, because the fuel your putting in has effectively bypassed the actual filter.
Luckily the times I've done it I've suffered no problems afterwards so maybe I was lucky. It really makes it so much easier filling it before refitting.
AlanH.
Post #365577 19th Oct 2014 8:03am
Jonno
That's what concerns me. Fuel added to the filter is effectively bypassing the filter. Knowing how fine the tolerances are in the injection system I'd consider it a bit of a risk.
I don't want to spend loads on a rubber bulb and bit of pipe, so might try the removing a fuel feed on the engine and lightly pressuring the fuel tank to bleed some fuel through.
It really would have been easier if LR had spent the 20 quid or so it would have cost them to fit a feed pump !
Jonno
Post #365616 19th Oct 2014 11:11am
munch90
do you honestly think in garages they muck about bleeding etc , 99% will tip the old filter into the new one then top up out of a jug
if your really lucky you might get it just filled from a jug of "clean" diesel ( must say this is what we do and do clean the jug out once in a while )
can never understand why they don't fit a small external electric pump something like a facet pump and just make them self prime
Post #365622 19th Oct 2014 11:30am
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
As the fuel pump is in the fuel tank and pushes the fuel up to the top of the engine the air in the system doesn't matter and will soon find it's way out. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #366015 20th Oct 2014 8:21pm
ickle
No pump in the tank on a tdci.
Post #366019 20th Oct 2014 8:36pm
Jonno
Apparently there is a pump on the 2.2 tdci but not the 2.4 did LR realise they had made a mistake? Or does the newer higher pressure pump have less sucking ability?
Jonno
Post #366029 20th Oct 2014 8:57pm
ickle
I stand corrected! Mines a 2.4 and there's def no pump in there.
As to JLR realising they made a mistake and improving the beast, if only! After 60 odd years we'd have perfection and nothing to spend all our free time & money fixing and improving and nothing at all to moan about!
keith
Post #366040 20th Oct 2014 9:38pm
MartinK
Resurrecting a VERY old thread!
So - looking at the evidence.
"EDFORS" says "Had to bleed a TDCi today, found that the connector to the fuel line is exactly the same as on the air inlet filter for the Discovery 2! So I used an old filter and cut the connector off, then connected a bladder and some hoses£... and his pic:
Looking at AndrewS write-up:
AndrewS wrote:
The home made one works Razz
This is the pump I made. As you can see there is only one connection on the 'tool' as I never connected the bleed tool in line. I simply placed the end of the pipe into a container to catch the fuel as it was pumped through. The other end was pushed into the female connector of the fuel line. It took about 2 minutes and about 2 pints of fuel before the fuel became air free.
Here is the Land Rover tool
A picture with dimensions of the male end of the Land Rover tool.
A picture with dimensions of the male end of the home made tool. As you can see its smaller in diameter but it sealed. Obviously I would like to get an end that is the correct Ų
This is the location of the connector that the bleed tool fixes to. Push the blue tabs in and pull the connector off the feed to the fuel pump.
Disclaimer
If you Censored your car up following these instructions its not my fault Razz Razz
I wonder this s would fit (LR Part # WJN500110, cost approx. £15)
Combined with a cheap hand pump for an easy home-made tool? Looks very similar to the part shown by AndrewS... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #638256 18th Jul 2017 3:37pm
MartinK
OK...here's mine - just used it for the 1st time...
I bought the LR Part # WJN500110 as above, and chopped-off the threaded portion with a hacksaw. Bought 2m of clear pipe from ebay (internal diameter 8mm, outside diameter 11mm), and an 8mm Fuel Primer Bulb Hand Pump.
The WJN500110 fitted inside the plastic tube perfectly...so I realized it may be slightly smaller in diameter than needed. So I wrapped a small amount of insulating tape to make a nice push fit. Perfect Thumbs Up
I pumped 1.5 litres of diesel before the bubbles stopped appearing in the tube! (the new fuel filter was put on empty). Like others I caught the pumped diesel in a container, and put the diesel back in the tank...
It's a job I wasn't looking forwards to, but it all went smoothly.
The Defender started up fine but she did cough a little for a few seconds
Glad I have the pump now - I will carry in the vehicle alongside the jack just in case I ever run out of fuel Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #640307 28th Jul 2017 12:38pm
MartinK
Pump: http://www.ebay.co.uk/itm/8mm-Fuel-Primer-...1438.l2649
Pipe: http://www.ebay.co.uk/itm/PVC-Tube-Clear-P...2749.l2649
About £20 all-in (pump, pipe, and LR part... Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #640311 28th Jul 2017 12:42pm
MartinK
Just an FYI - if I did this again, instead of buying the WJN500110... I would try LR019009 (no guarantees but it looks more likely the right diameter / fit...and a bit cheaper too!)
It's off the end of one of the Puma fuel lines...and looks like it has the same female connector Thumbs Up
Next time I place an order for filters etc, I'll order one at the same time and try it (not paying £6 postage coz I am tight and just done the job anyway!) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #640314 28th Jul 2017 1:11pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
LR019009 is to short, going to try to turn it down in a lathe and remove the hex to make it longer.
Post #647203 30th Aug 2017 3:38pm
MartinK
Mark - let us know how you get on please. Happy with my pump the way it is just now, but if a fetter solution arises for a few £, I will upgrade Smile
Maybe a pic of your final solution? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #647336 31st Aug 2017 7:49am
