Home > Puma (Tdci) > Puma fuel bleeding pump |
http://cgi.ebay.it/Diesel-Injection-Primin...1964wt_912
http://cgi.ebay.it/DIESEL-ENGINE-FUEL-PRIM...2098wt_912 or http://shop.ebay.it/?_from=R40&_trksid...iming+Tool Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th Sep 2010 1:17pm |
From where I'm from that looks like a half decent glass of 'central heating for tramps' (cider) and good enough to guzzle! Gotta be said Andrew you do come up with some brilliant solutions and quick fixes. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Sep 2010 1:22pm |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 |
oh cavolo.... ho proprio bisogno di ferie.... I need vacation....very urgently!!!! Matteo Defender 110 Td4 SE MY 09 |
6th Sep 2010 1:29pm |
6th Sep 2010 1:33pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1788 |
The outlet on a Freelander 2 fuel filter cartridge appears to be the same as the one required. With a bit of inginuity and a bleed bubble (rover 25 diesel?) should be possible to make something for very little cost.
Does anyone know the easy way (apart from paying someone else) to change the oil filter on a F2 without getting warm oil down your arm? |
19th Sep 2010 8:55pm |
zebra Member Since: 01 Jul 2010 Location: genova Posts: 18 |
Hi, I've bought a bleeding pump on ebay (http://cgi.ebay.it/DIESEL-ENGINE-FUEL-PRIMING-PUMP-/110475636037?pt=UK_Measuring_Tools_Levels&hash=item19b8dc6d45#ht_2098wt_912) the male connection has the same dimension of the land rover tool, only the transparent rubber pipe length is shorter. But I have a doubt, can you explain me which is the correct direction of the fuel in the pump???? In my pump the direction is from the male to the female connection (there is an arrow on the pump..) while in the AndrewS post, I’ve understood that he take the fuel from an external tank and pump it in the fuel circuit across the male connection. this is just a problem of my bad English ?????? Ciao Lorenzo |
27th Sep 2010 10:13am |
Ciao Lorenzo, your pump is correct!!the flux is from the male to female.
You must pump the fuel until there are more bubbles! Matteo Defender 110 Td4 SE MY 09 |
27th Sep 2010 12:17pm |
thank's matteo
ciao Lorenzo |
27th Sep 2010 12:46pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
Did you fill the new filter with diesel before replacing it? |
29th Sep 2010 7:27am |
always!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
29th Sep 2010 12:02pm |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
Here is my input (at 40 000 km):
Cheers! Janusz www.yahodeville.com |
6th Oct 2010 9:38am |
Is that from draining the filter in the rear wheel arch? |
6th Oct 2010 10:16am |
Yes, the cup size is c.a. 200 ml Janusz
6th Oct 2010 10:46am |
Just finished the job with the bleeding pump.
There is no need to have any connector on both sides of the pump: - female end goes straight to an empty container - initially I have tried male connector but I could not have a good sealing - end of the pipe changed to 10 mm (outside diameter) solved the problem - fits there with perfect sealing Janusz www.yahodeville.com |
6th Oct 2010 1:51pm |
Did you try putting the filter back without doing this bleeding thing? If so what happened? |
6th Oct 2010 1:58pm |
