Home > Puma (Tdci) > help have i got the wrong stat |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
to me, th first stat is an engine stat, the controller of the engines temp.
the second one looks like a heating circuit stat, with a bypass to mix the flow. not 100% but i'd be changing the first one. |
18th Jan 2015 2:50pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1916 |
would there be two? the engine cooling section on the work shop manual states the second one.
land rover gave me part no LR004618 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
18th Jan 2015 2:54pm |
only one stat fitted and its the bottom one called prt thermostat ( pressure relief thermostat )
comes as a sealed unit come in 3 different colours and temps gray 82c light spring black 82c hard spring cream 87c medium spring (standard one ) |
18th Jan 2015 3:20pm |
i am really confused now, when i put the part number in google it brings up the top one, some sites say "the house stat not the hose one"
when i google defender pump thermostat mostly the bottom picture shows but saying that most of the aftermaket suppliers show the top one 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
18th Jan 2015 3:30pm |
its the bottom one
18th Jan 2015 3:34pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Puma has two according to the parts catalogue.
The white bodied one alongside the radiator like the Td5 - PEM100990K And the LR004618 part you've been given, which is in here: Click image to enlarge 1988 90 Td5 NAS soft top 2015 D90 XS SW |
18th Jan 2015 3:53pm |
Thanks Martin! Now which one is likely to cause over heating? I presume the one on the back of the pump will open once the engine reaches temp And the same for the plastic housing type for the heater, that said this one is unlikely to cause any over heating? Just cold heaters? 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
18th Jan 2015 4:00pm |
that picture is a transit thermostat housing
NOT A DEFENDER THE HOUSING IS NOT FITTED TO A DEFENDER AND THERE IS ONLY ONE THERMOSTAT the metal bracket shown in the picture that the housing bolts to is the bracket at the top front right of the engine (as you look at front ) where the glow plug wire joint is ON A TRANSIT |
18th Jan 2015 4:41pm |
That's fine, but I got it from an LR parts catalogue - traced using the LR part number given. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
18th Jan 2015 4:57pm |
ive just changed mine three times playing with the different colours and temps ( in the " too low coolant temps " thread )
18th Jan 2015 5:02pm |
Much90 as much as i think the same as you the facts are against us!
Land Rover gave this stat, the web shows it for the 2.4 tdci, the work shop manual shows it in the rear of the pump BUT the fitting instructions only show the other plastic assembly? 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
18th Jan 2015 5:08pm |
http://www.mse.org.uk/Forum_Stuff/DSC00290.JPG
see the big wiring loom at the front top of engine , you can see the metal peg sticking out under it by the top hose and cable tie , that's the metal bracket ( number 4 ) shown in martins diagram picture Last edited by munch90 on 18th Jan 2015 5:20pm. Edited 3 times in total |
18th Jan 2015 5:13pm |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
And that's the exact same diagram that's in my manual also. I started with nothing and still have most of it left! |
18th Jan 2015 5:14pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5699 |
Bit off topic. But why are you changing the stat?
I thought you were going to fit new sender Andy |
