Home > Puma (Tdci) > help have i got the wrong stat
Page 2 of 3 <123>
T1G UP
change the traditional stat. its in the block for a reason. the other one it to speed up the heating of the heater...
Post #389890 18th Jan 2015 6:17pm
bear100
Hi Andy, I am going to flush out and change the coolant as its due soon and as I have the stat here I was going to change it anyway, but it's proved harder than I thought!! Shocked 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #389891 18th Jan 2015 6:19pm
landy andy
It always ways does turn out harder than it should be. Evil or Very Mad
Post #389913 18th Jan 2015 7:01pm
munch90
Please do a report on your findings
never seen a engine with two thermostats
Post #389958 18th Jan 2015 8:19pm
Cheshire110
Sorry didn't read the whole thread above (out) but it's the plastic housed thermostat that I replaced & sorted my problem. It wasn't opening in warm water when I tested it.
This is the one I bought http://m.ebay.co.uk/itm/331132538262?_mwBanner=1
Replied to your Pm too Bear100 Thumbs Up Cheers, David
Post #389977 18th Jan 2015 9:02pm
munch90
Thats the one
Post #389983 18th Jan 2015 9:26pm
dgardel
Italy
munch90 is right
only the external (plastic housing) thermostat Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #390059 19th Jan 2015 12:33am
nickhodgson
The plastic one is the Puma one the other one looks like a 300tdi thermostat. The part number for the Puma thermostat (the plastic one in the earlier pictures) is the same as for a TD5 so its a part that has been used for a while. What is the problem? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #390090 19th Jan 2015 8:47am
munch90
dgardel wrote:
munch90 is right
Thank you
Post #390097 19th Jan 2015 9:28am
bear100
Neutral so we can say Land Rover parts catalogue and the dealer and the work shop manual is incorrect?
Has anybody ever looked or changed the water pump? According to the manual there is one there??
Still just as confused Sad 2023 Defender L663 V8
Post #390137 19th Jan 2015 11:34am
munch90
not in my manual there isn't , no mention of a thermostat near the pump
Post #390140 19th Jan 2015 11:38am
x-isle
Just to throw a spanner in.......
Isn't there the normal (plastic y-shaped one) thermostat which controls the water bypass for the heating circuit, but also another thermostat which controls the flow through to the oil cooler? Or is this integral to the oil cooler?
To quote the workshop manual;
"The engine cooling system cools the oil in the oil cooler and is regulated by means of a separate thermostat, which
prevents the flow of coolant through the oil cooler when the engine is cold, ensuring the engine oil warms up quickly.
The thermostat opens at 75±2°C (167±35°F)."
 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #390144 19th Jan 2015 11:48am
munch90
the oil cooler thermostat is in the little plastic pipe the joins to the oil cooler on the filter housing
and before anyone says it must be the top one in the first post picture , no it isn't , the cooler one is very small comes as part of the pipe is held in with one bolt and has a o ring to seal it
there is also a thermostat for the fuel and yes its not that one either Rolling with laughter
Post #390149 19th Jan 2015 12:03pm
x-isle
....but to answer the "which one is causing overheating".
If the ickle-micro-thermostats are not working then;
Oil cooler not cooling and/or fuel cooler not cooling could help towards engine getting hot.
However, I'd be more inclined to say it was the plastic jobby.
With the ones fitted to the Transit missing, I assume that the plastic one has been introduced due to the fact that the water has to flow to non-transit stuff. Therefore, the redesign took out the original Ford thermostat housing and replaced it with the well-known LR one. Craig Rogers
2007 Puma 110 XS
Post #390152 19th Jan 2015 12:19pm
munch90
"plastic jobby" is the one that controls engine temp
yes remote plastic jobby replaces transit set up
Post #390153 19th Jan 2015 12:21pm
Page 2 of 3 <123>
