Home > Puma (Tdci) > help have i got the wrong stat
Page 1 of 3 123>
bear100
ok this may sound stupid Embarassed
i have a new thermostat from land rover and looks like this
i am now looking at the online workshop manual and the thermostat looks like this
have i got the wrong one or does the white housing come apart? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #389812 18th Jan 2015 2:34pm
T1G UP
to me, th first stat is an engine stat, the controller of the engines temp.
the second one looks like a heating circuit stat, with a bypass to mix the flow.
not 100% but i'd be changing the first one.
Post #389821 18th Jan 2015 2:50pm
bear100
would there be two? the engine cooling section on the work shop manual states the second one.
land rover gave me part no LR004618 2016 Range Rover Autobiography 4.4 TDV8
Post #389822 18th Jan 2015 2:54pm
munch90
only one stat fitted and its the bottom one called prt thermostat ( pressure relief thermostat )
comes as a sealed unit
come in 3 different colours and temps
gray 82c light spring
black 82c hard spring
cream 87c medium spring (standard one )
Post #389831 18th Jan 2015 3:20pm
bear100
i am really confused now, when i put the part number in google it brings up the top one, some sites say "the house stat not the hose one"
when i google defender pump thermostat mostly the bottom picture shows but saying that most of the aftermaket suppliers show the top one
Question Question Question Question Confused Confused Confused Confused 2016 Range Rover Autobiography 4.4 TDV8
Post #389838 18th Jan 2015 3:30pm
munch90
its the bottom one
Post #389840 18th Jan 2015 3:34pm
Martin
Site Admin
Puma has two according to the parts catalogue.
The white bodied one alongside the radiator like the Td5 - PEM100990K
And the LR004618 part you've been given, which is in here:
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #389847 18th Jan 2015 3:53pm
bear100
Thud Thud Banging Head Banging Head
Thanks Martin!
Now which one is likely to cause over heating?
I presume the one on the back of the pump will open once the engine reaches temp
And the same for the plastic housing type for the heater, that said this one is unlikely to cause any over heating? Just cold heaters?
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
Post #389848 18th Jan 2015 4:00pm
munch90
that picture is a transit thermostat housing
NOT A DEFENDER
THE HOUSING IS NOT FITTED TO A DEFENDER AND THERE IS ONLY ONE THERMOSTAT
the metal bracket shown in the picture that the housing bolts to is the bracket at the top front right of the engine (as you look at front ) where the glow plug wire joint is ON A TRANSIT
Post #389869 18th Jan 2015 4:41pm
Martin
Site Admin
That's fine, but I got it from an LR parts catalogue - traced using the LR part number given.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #389874 18th Jan 2015 4:57pm
munch90
ive just changed mine three times playing with the different colours and temps ( in the " too low coolant temps " thread )
Post #389879 18th Jan 2015 5:02pm
bear100
Much90 as much as i think the same as you the facts are against us!
Land Rover gave this stat, the web shows it for the 2.4 tdci, the work shop manual shows it in the rear of the pump BUT the fitting instructions only show the other plastic assembly? 2016 Range Rover Autobiography 4.4 TDV8
Post #389883 18th Jan 2015 5:08pm
munch90
http://www.mse.org.uk/Forum_Stuff/DSC00290.JPG
see the big wiring loom at the front top of engine , you can see the metal peg sticking out under it by the top hose and cable tie , that's the metal bracket ( number 4 ) shown in martins diagram picture
Post #389886 18th Jan 2015 5:13pm
Rickydodah
And that's the exact same diagram that's in my manual also. Confused I started with nothing and still have most of it left!
Post #389887 18th Jan 2015 5:14pm
landy andy
Bit off topic. But why are you changing the stat?
I thought you were going to fit new sender
Andy
Post #389888 18th Jan 2015 5:14pm
Page 1 of 3 123>
