Home > My Defender > Overland 110 Build from the Ground Up!
Page 7 of 11 <123 ... 678 91011>
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
Thanks for the plug T1G!
The best place to look for our 100" V8 Auto Here http://www.yorkshireoffroadclub.net/forum/...&t=194 - although this only covers the change from Rover V8 to LS1 - we did the 110 to 100 several years before that and havent got a Webpage for that. If you want any info re. the chassis drop davew a PM a and he will talk you through it.
My 90 rebuild here - http://www.yorkshireoffroadclub.net/forum/...&t=678 and expedition modifications here http://www.landytravels.com
Re. Compressor and air tank - we put those behind the passenger seat on my 90, on top of the seat box. Should be a pic somewhere on the Landy travels blog.
Re. Water tanks. We did consider a single built in water tank but with limited space in the 90 we decided on a more 'flexible' system of separate plastic 10l containers, which could be put into odd spaces etc. in practice we found this was a really good idea, but not just re. space. It was more that one big water tank is like putting 'all your eggs in one basket'. The main issue we had with water was drinkability - some of the water we got in Austalia was technically fit for comsumption but it was quite nasty taste wise or, especially in the west, quite salty. So we could fill a single container with it for washing etc, and save better water we'd got elsewhere for drinking and not waste it on washing. Nothing worse than trying to quench your thirst on a long gorge walk in 30 degree heat when you only have salty water to drink. (Buying bottled water to have in the fridge for drinking was also a good habit to get into!!) We were able to swap over and refill the individual water containers without the risk of contaminating the whole lot with a bad batch. There is also the issue of leaks - if 1 container leaks and that's all you have, you are stuffed, whereas having separate ones you are proofed against losing all your water ! Anyway, just something to consider. Smile Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #389359 17th Jan 2015 1:43pm
Defender_Td5
1991 Defender 110 300 Tdi USW Stornoway Grey
Hi Pam,
Thank you for the useful advice, I had a look at your truck's build thread....very nice it is too! It looks like you enjoyed Australia as well. I can't wait to get back to Aus and get on with my list....I have been purchasing a few more items as well while I have been away.
Hi Ronin,
I bought the light guards from Devon 4x4, however I have checked the website and it would appear that they don't stock them anymore. The Masai ones are a very good match apart from the bit of free advertising down the front!
Rob Defender 300Tdi 110 Utility Wagon ROW Overland
Series 1 86"
Post #389713 18th Jan 2015 12:04pm
Defender_Td5
As with all things generally relating to Defenders, the list has grown a bit now! Here is an update of the upcoming works:
- Finally wire up the Light Force 170 roof rack spot lamps
- Wire up the two rear LED flood lamps
- Fit two new Tdci XS Heated front seats and wire these up
- Fit new XS seat covers purchased for the Tdci Second Row Seats to match the front.
- Remove all wheels and tyres - wheels to be repainted in satin black and the BFG KM2's taken off and replaced by 265 75 16 General Grabber AT2's. I will keep the BFG KM2s for muddy adventures.
- Remove and service the front double de-cardan propeller shaft.
- Remove both rock sliders, fit �halfmoon� jacking points fwd and aft of both rock sliders � Sized for the Land Rover Hi-Lift jacking adaptor.
- Both rock sliders to be galvanised and then re-powder coated.
- Remove front and rear anti roll bars - blast and powder coat both.
- Remove radiator top surround, blast and re-galvanise.
- Remove radiator top mounts x 2 � blast and galvanise.
- Remove fuel filter bracket � blast and galvanise.
- Remove snorkel and pre-filter steel top, blast and powder coat both.
- Remove cracked O/S wing, strip off outer wing skin and wheel arch � replace and have repainted in Stornoway Grey � Paint Code LRC 907
I think that should keep me busy for a week!
Series 1 86"
Post #390072 19th Jan 2015 4:44am
Darcy Fairfax
England 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Massive thumbs ups Thumbs Up
Post #390100 19th Jan 2015 9:42am
Ronin
United Kingdom 2014 Defender 90 Puma 2.2 ST Keswick Green
Thank you very much Grenadier and Rob - they're exactly what I am looking for.
Cheers,
Joel Thumbs Up
Post #390107 19th Jan 2015 10:03am
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
Such an inspirational read, well done Thumbs Up pity Land Rover don't employ a few people like yourself. Thumbs Up Adventure isn't paved!
Post #390308 19th Jan 2015 8:17pm
shaggydog
I have a feeling in the next few years there will be quite an upsurge in people wanting land rovers rebuilt as the supply of shiny new ones to do drys up.
Skills will be in demand! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #390348 19th Jan 2015 9:09pm
Welkman
Come on rob a few more updates then it will be ready for me to borrow when I pop out to Australia Laughing
James
Post #395415 3rd Feb 2015 12:17pm
Defender_Td5
Back in the country end of next week....I have the following week off for Land Rover based build stuff. I'll post up an update soon...
Series 1 86"
Post #395417 3rd Feb 2015 12:21pm
Defender_Td5
Hi All!
Finally an update! Sorry it took so long...
So, first on the list was the change out the front seats for some recently purchased Puma XS Heated ones, these where bought over from the UK and had only done delivery miles before being removed for an upgrade by the previous owner:
"Old" Outlast Covered Standard Tdi Seats:
New Tdci Seats all fitted:
I got lucky with an eBay purchase of some second row XS Puma covers to match the fronts, I have now fitted these thanks to an excellent guide on this forum:
Front and Rear Anti Roll Bars Blasted back to bare metal:
Back from the Powdercoaters (satin black in place of the original bright orange), I also took the opportunity to have the mounts blasted and galvanized at the same time:
Both rock sliders were removed and had jacking points installed, this involved taking out a "half-moon" shape and welding in some 4mm tube that was cut to fit:
Both were then blasted:
And galvanized:
I then tried them out on the Defender, but decided I preferred them powdercoated as they were originally, so I am having these done as well:
The front propeller shaft came back from reconditioning, the splines were excessively worn, which has me a bit perplexed as the vehicle has only done 14,000 miles and I had been greasing both front a rear prop-shafts regularly. As a matter of course they also replaced all three UJ's and rebuilt the center cardon joint as well.
All five Blindo wheels were reconditioned as they had gotten pretty scratched up by offroading, the BFG KM2's were removed and replaced with some General Grabber AT2's in 265 75 R16 size, I'll keep the KM2's and mount them on a set of Wolf rims that I have purchased. It's amazing the difference between the KM2's and the AT2's on the road in terms of noise reduction and steering vibration.
I also removed the front and middle head-linings and tidied up the wiring with some self adhesive clips:
That's where I am currently, a bit more to follow in a few weeks. Here is my other toy when it was in for a full dyno tune, it's a KTM 990 Adventure.
Cheers all.
Rob
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Defender 300Tdi 110 Utility Wagon ROW Overland
Series 1 86"
Post #414930 9th Apr 2015 4:56am
Welkman
Nice welding rob. Are the jacking points for the high lift? Just to secure the lifting point? Also do you think I could get a 990 smt past Becky ? Laughing
Post #415078 9th Apr 2015 7:23pm
Defender_Td5
Yeah, they are for a Hi-Lift, or rather a Hi-Lift with the Land Rover tube type jacking adapter fitted on to it that you can buy. This allows you to use the Hi-Lift in the normal jacking points in each of the vehicles chassis dumb-irons and in the circular jacking point holes in the rear cross-member.
I had always wanted some proper jacking points on the sills and having used the Hi-Lift without a "retainer" as such, it just wasn't a pleasant experience, now at least I have the half circles to stop the jack from moving about or worse sliding out.
I don't know about an SMT, why not just get an Adventure? Much better looking bikes....
Series 1 86"
Post #415145 9th Apr 2015 11:14pm
Brewstop
United Kingdom 2002 Defender 110 Td5 CSW Zambezi Silver
This thread is comprehensive land rover porn for me - Thank you! Sandy
Post #421008 4th May 2015 8:42am
Looking good Thumbs Up
How did you decide where to place the hi lift cut-outs in the rock sliders?
Post #421033 4th May 2015 10:34am
Defender_Td5
haha! Thank you! More to follow..... Defender 300Tdi 110 Utility Wagon ROW Overland
Series 1 86"
Post #425710 23rd May 2015 10:13am
