Home > My Defender > Overland 110 Build from the Ground Up!
Page 2 of 11 <123 ... 91011>
grizz
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
wow ..... Bow down
I've built a 90 and 110cs from the ground up but this is amazing ..
Post #363408 9th Oct 2014 4:57pm
gusjam
Scotland 2005 Defender 110 Td5 DCPU Stornoway Grey
in my head (dreams) this is exactly what i'd love to do on a 90, in reality i've yet to learn the skills and the knowledge to do so. I keep reading this forum in the hope that some of it will rub off on me! in the meantime i canny wait for the next installation of this build Smile
Post #363414 9th Oct 2014 5:34pm
gilarion
Excellent, having done similar myself i know the hard work you have put into it. Looks a beauty Thumbs Up
Post #363416 9th Oct 2014 5:41pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
very, very nice!
Post #363428 9th Oct 2014 6:17pm
GUM97
Impressive, looks really well done! Mr. Green Thumbs Up An engine to TDi for!
Post #363430 9th Oct 2014 6:23pm
BigM
Kenya 1985 Defender 110 300 Tdi HCPU Auto Bonatti Grey
Impressive, well thought through, executed and presented. This is an inspired gift to us all who would love to do the same.
All best from Kenya where such a 110 would suit conditions here.
BigM
Post #363432 9th Oct 2014 6:27pm
Defender_Td5
1991 Defender 110 300 Tdi USW Stornoway Grey
Thank you for all the replies, I had better keep on going then...
Onto some bodywork - the B-Posts! These are well know major rust spots on 110 CSW and mine really didn't disappoint. While I was up in Aberdeen I managed to purchase another pair which were just about worth saving as mine that came with the 110 as purchased were completely shot.
This is one of the B-Posts during repair, basically the entire lower part of the B-Post had to be completely rebuilt was new steel:
Cover plate welded on and all flatted back:
The sills were also pretty shot, so a new set was folded out of 3mm steel:
Sill to Bulkhead fixing ends were fabricated as copies of the originals:
The repaired B-Post was then positioned on the sill:
The C-Posts were also in quite a state:
A simple jig was make to hold the C-Post in place while the new sections were bent up and spot welded in place:
New steel was folded up exactly to the original profile:
And spot welded in place:
To align the C-Post with the B-Post an old secondhand door was bolted up and measurements were taken from a friends 110.
Comparison between the old and new:
Once complete both the completed B-Posts were bead blasted and hot dip galvanized:
Good for the next 50 years hopefully! They were then T-Washed, cleaned and painted Stornoway Grey and bolted onto the chassis:
Regards
Rob
Post #363511 9th Oct 2014 9:47pm
Defender_Td5
NEXT!
A whole load of parts went off to be shot blasted and then either re-galvanized or be galvanized as Land Rover should have done at the factory (i.e door frames, brake disk dust protectors, fuel tank strap etc).
Some parts back from galvanizing, I am planning on building the doors up with the new style electroplated door skins to try and address the dreaded Defender door rust issues:
While the shot blasting and galvanizing was going on, lots of panels were stripped back to bare aluminum with the two part aircraft grade paint stripper I mentioned earlier on. It is really good stuff.
Also got busy and purchased more some parts! This is the spare room at home with around 50 to 70 packages of all shapes and sizes.
Regards
Rob
Post #363516 9th Oct 2014 10:03pm
shaggydog
Beautiful beautiful work.
Mine is having a bit of a rebuild soon (which I thought was extensive until I saw yours Shocked)
Glad to see another TDI brought back to life!
You are clearly doing it the way it should have been done from the factory. Fantastic work
Keep the updates coming they are giving me ideas and ideas and bits to check Very Happy
Post #363519 9th Oct 2014 10:14pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Rob,
Excellent job and great to see some quality work. You'd put a lot of these 'professional' rebuilds to shame with your work.
What is the make of paint stripper you are using?
Keep up the good work Thumbs Up
Steve
Post #363521 10th Oct 2014 12:02am
Defender_Td5
Hi Steve,
Thank you for the praise. I put a lot of thought and planning into how exactly I wanted to put this one together and after the previous rebuilds I had done, I learned a lot about how to do it the right way! I wanted to build a vehicle that didn't just look good, but was built to last and be used for what it was intended for.
The company that supplied the paint stripping solution was called "Strippers Paint Removers" they can be contacted on 01787 371524. Here is a link to their website:
http://stripperspaintremovers.com/view_products.htm
To completely strip a Defender 110 of all paint (I mean both sides of the panels) I used around 25L of stripper. It is not nice stuff though and will burn through household rubber gloves in no time! I ended up putting on two layers of really thick industrial cleaning gloves.
Rob
Post #363524 10th Oct 2014 12:55am
gilarion
Yet again I have to congratulate you on your skilled work. I could do with you as a neighbour Wink
Post #363592 10th Oct 2014 1:37pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Hi Rob,
This is truly amazing work and based on your pictures probably the most extensive rebuilt I've even seen.
Congrats and really looking forward to see the final result Thumbs Up
Keep up the excellent work Mr. Green Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #363611 10th Oct 2014 4:25pm
redzob
Guernsey 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi Rob,
Simply amazing. I'm in total awe.
Thumbs Up Defender Puma 2.2 XS 90
Vespa GTS 300
Way too many racing bikes.
Post #363625 10th Oct 2014 6:00pm
X4SKP
Hi Rob,
I can only echo others on here... absolutely top job, well done.
On top of actually doing the work, taking the time to post it up too... Thumbs Up
This one looks to be setting the bench mark for rebuilds...
Definitely going to follow this until the end...
keep it up hardly seems necessary Exclamation SKIP
Post #363627 10th Oct 2014 6:07pm
