![]() | Home > My Defender > Overland 110 Build from the Ground Up! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17667 ![]() ![]() ![]() |
Outstanding! Very impressive range of parts available, definitely good to see. |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 207 ![]() ![]() ![]() |
Well you never quite know the circumstances when someone sells their dream truck. It's sad to think it happens but priorities change ![]() Ah Rob, small world. Alex got in touch with me last year and I think things fell under the radar. Get in touch if you're still interested. I'd love to come see your setup when the world is normal again. So are JLR classic selling on your behalf, rather than them buying it from you? LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 867 ![]() ![]() ![]() |
I've just re-read the whole thread and I must say your attention to detail is impressive. Do you recall where you got the engine bay sound proofing from? It looks incredibly similar to the factory fitted stuff I've seen which itself is much better than anything else I can see on the market.
Cheers. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2216 ![]() ![]() ![]() |
Gorgeous truck
It looks as though someone did a good job removing all traces of the roll cage. I wonder how all the holes were patched.
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
i just thought the same blackwolf
Defender_Td5 Member Since: 20 Jul 2009 Location: Devon/Australia Posts: 69 ![]() ![]() |
The cage was removed and the holes were carefully TIG welded up and ground back. After the new paint job they became invisible! Defender 300Tdi 110 Utility Wagon ROW Overland
Series 1 86" |
westcoast1 Member Since: 14 Oct 2022 Location: Scotland 🏴 Posts: 1 ![]() ![]() ![]() |
Amazing build, especially liking the attention to detail of the wiring. Don’t suppose you could share the diagram you made? All the best |
