Home > My Defender > Overland 110 Build from the Ground Up!
Page 9 of 11 <123 ... 8 91011>
fathaggis
this defender is in a league of its own ..... Bow down its should have one of the magazines do a spread on it .. its that good Bow down Thumbs Up
Post #438207 16th Jul 2015 10:26am
Welkman
I found doing electrics on yachts has helped no end with car electrics as everything has to be to a really high standard for insurance, also the systems for a small boat are similar in terms of aux fuse boxes, split charging and cable protection. I used this book to teach myself
Post #449947 28th Aug 2015 7:52am
need4speed
That's a good shout Welkman Thumbs Up I'm pretty good mechanically but the one aspect of my build that I've needed a lot of help with is the electrics.
PaulMc on here has been a real life saver for me. I have a 4.6 V8 fitted with Megasquirt in my 110 so a lot of the TD5 loom was totally redundant. Paul told me what I could safely remove from my harnesses and even made up some custom ones for me for my engine and Raptor console etc etc.
Something like that book you refer to could really help me get my head around that aspect of things... Thumbs Up
Post #450070 28th Aug 2015 1:21pm
Pickles
need,...4.6 & "megasquirt"?.....excuse my ignorance, but what is a "megasquirt"?....anyway a "4.6" in a 110 sounds interesting (any V8 does to me!!)....any pics, engine bay etc?
Pickles.
Post #450235 28th Aug 2015 9:56pm
AndrewS
Great build Thumbs Up 130's have feeling's as well you know Smile
Post #450267 29th Aug 2015 7:16am
need4speed
Pickles.
Here you go Pickles..
http://www.megasquirt-v8.co.uk/ms_what_is_ms.php
And a link to my build- it's easier than going over it again Thumbs Up
http://forums.lr4x4.com/index.php?showtopic=46671
I really need to update the thread as lots has been done since but I'm in such a tight garage now taking decent pics is very difficult. It can be a challenge just getting round the LR to work on/in it.... Laughing
Post #450299 29th Aug 2015 9:45am
Defender_Td5
1991 Defender 110 300 Tdi USW Stornoway Grey
Over 20k views! Well I never, ever expected my thread to be so popular, thank you to everyone who has taken the time and effort to read the whole thing right the way through. I must apologise for being a little quiet on here recently, I have been flat out with work and also have taken on rebuilding a 1975 Series 3 SWB (owned by a friend, who is learning mechanics as we go) here in Australia:
As bought after part dismantling (rare chicken edition):
The state of the chassis:
Repaired Bulkhead and Chassis:
Bulkhead Repairs:
Core plug hole repaired:
Rebuilt Front and Rear Axles, including differentials as well. Every seal, gasket and bearing was replaced due to salt water damage (the vehicle had been used on the beach extensively by the previous owner) and lack of maintenance:
Currently as the project stands:
An order has arrived from the UK for the Overland 110 as well, consisting of the following:
- 6 x Wolf Tubeless Wheels (these will be fitted with 255 85 R16 BFG KM2s and used solely for off-roading)
- 1 x Blindo Wheel (to carry as an additional spare and will be fitted with the same General Grabber AT2 tyre)
- D44 front weld on aluminum housing protector (in black, red was a bit bright!)
- Full Superpro bush replacement kit.
- 1 x Ashcroft front diff locking unit
- 2 x Ashcroft HD CV joints
- 2 x Ashcroft HD front half-shafts
That will take care of the drive-train strengthening upgrades, given the rear axle is already done this will also future-proof the vehicle as well for a possible engine and gearbox upgrade.
I'll update the Defender build once I get my teeth stuck into it again.
Watch this space!
Rob
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Defender 300Tdi 110 Utility Wagon ROW Overland
Series 1 86"
Post #450727 31st Aug 2015 5:51am
Awesome. That is all.
Post #450734 31st Aug 2015 7:17am
rustandoil
Just read the whole thread from the beginning, your attention to detail is what stands out, well done Bow down Bow down
Post #450745 31st Aug 2015 7:58am
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
You should do rebuilds for a living, I'd happy pay over the odds for your services Thumbs Up
Post #450791 31st Aug 2015 10:14am
Oldyellar
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Amazing work Cool
Post #462937 13th Oct 2015 4:13pm
T1G UP
Defender_Td5 wrote:
Hi All!
Finally an update! Sorry it took so long...
So, first on the list was the change out the front seats for some recently purchased Puma XS Heated ones, these where bought over from the UK and had only done delivery miles before being removed for an upgrade by the previous owner:
"Old" Outlast Covered Standard Tdi Seats:
New Tdci Seats all fitted:
I got lucky with an eBay purchase of some second row XS Puma covers to match the fronts, I have now fitted these thanks to an excellent guide on this forum:
Front and Rear Anti Roll Bars Blasted back to bare metal:
Back from the Powdercoaters (satin black in place of the original bright orange), I also took the opportunity to have the mounts blasted and galvanized at the same time:
Both rock sliders were removed and had jacking points installed, this involved taking out a "half-moon" shape and welding in some 4mm tube that was cut to fit:
Both were then blasted:
And galvanized:
I then tried them out on the Defender, but decided I preferred them powdercoated as they were originally, so I am having these done as well:
The front propeller shaft came back from reconditioning, the splines were excessively worn, which has me a bit perplexed as the vehicle has only done 14,000 miles and I had been greasing both front a rear prop-shafts regularly. As a matter of course they also replaced all three UJ's and rebuilt the center cardon joint as well.
All five Blindo wheels were reconditioned as they had gotten pretty scratched up by offroading, the BFG KM2's were removed and replaced with some General Grabber AT2's in 265 75 R16 size, I'll keep the KM2's and mount them on a set of Wolf rims that I have purchased. It's amazing the difference between the KM2's and the AT2's on the road in terms of noise reduction and steering vibration.
I also removed the front and middle head-linings and tidied up the wiring with some self adhesive clips:
That's where I am currently, a bit more to follow in a few weeks. Here is my other toy when it was in for a full dyno tune, it's a KTM 990 Adventure.
Cheers all.
Rob
you must be my brother from another mother! i have an orkney grey 110 ( utility sides now fitted ) with black blindos and a 2009 white ktm 990 adventure with akro cans and a remap! Thumbs Up another man of great taste :bow:
Post #462946 13th Oct 2015 4:28pm
T1G UP
Defender_Td5 wrote:
Hi All!
And galvanized:
Cheers all.
Rob
Post #462947 13th Oct 2015 4:28pm
Defender_Td5
Hello!
Merry Christmas to all! I am finally back with an update....so read on and hopefully enjoy.
Breathing Issues:
The Wolf Army spec Donaldson filter that I had fitted to the truck has performed very well, however during a routine service the plastic mounting band which holds the filter to the engine mount snapped in half. I wasn't very impressed by this and set about sourcing a metal band from Donaldson directly.
Removal of the housing also showed that the inlets and outlets had been overly compressed by the hose clips, I addressed this issue by sourcing some slightly undersized aluminum tubing and then inserted into both the inlet and outlet, securing them in-place with Araldite two part slow setting epoxy glue:
A new mounting system had to be made up to mount the different metal securing band, the old plastic mount was bolted to the original 300Tdi flexi rubber mounts, however the new system is hard mounted to the air filter support bracket, it gives a much stronger mount that is now lease prone to flexing and rubber deterioration.
A piece of 3mm aluminum was then used to direct mount the new metal band:
However with the new steel air filter box mount in place, this altered the alignment of the air-intake hose which meant the Land Rover offering was no longer, long enough without putting undue stress on the mounts:
So the hose was split at the joint and a insert piece was purchased in three ply silicon, again the flanges were strengthened with aluminum tube inserts which were Araldited in place and then the extension piece was hose clamped together, one more hose clip still to go on in this picture:
While on the subject of breathing, I also purchased a MANN Provent 200, this will be fitted soon and will hopefully address the 300Tdi crank case breathing issues which all the engines suffer from to a degree:
Following on from a slightly enthusiastic off-roading expedition, I ended up with quite a large amount of muddy water in the truck, this time it had got into the carpets, so everything had to come out for a proper clean up, including the rear storage chests:
Bits of Land Rover everywhere:
I took the opportunity to address some slight aluminum corrosion that had started around the mountings for the rear seats and the rear storage chest:
The rear floor was then covered in Dynamat:
Carpet re-installed:
New BFG KM2s in 255 85 R16 mounted on Genuine Land Rover Wolf Rims. These are now my off-road wheels and tyres as I was fed up with trashing my rather nice Blindos!
Out for an adventure with some friends:
Defender wins!
Awesome day in the mud:
New air-intake hose got tested:
Twin ARB compressor purchased and awaiting installation:
What to do with the old ARB compressor? Make it into a mobile air source of course, mounted into a Spacecase:
I was still suffering from a slight drive-train vibration and was convinced it was propshaft related, so a call to Gwyn Lewis in the UK and one of his amazing double cardon HD props later and guess what, no drive-train vibration at all:
Still yet to be fitted is my D44 HD front Diff guard, this will go on when I pull the front axle off to add the Ashcroft Halfshafts and CVs:
Finally got around to fitting my Madman Engine Monitoring System, more on this in the future:
EGT Probe install as a part of the Madman kit:
The clutch master cylinder gave up the ghost and dumped all its fluid all over the housing, which kindly stripped all the paint off, so that had to come out for a re-paint and fitting of the new cylinder. I also fitted a later cross drilled clutch pivot pin that has a grease nipple in the end, the result is a clutch that now doesn't squeak!
Resting up before the next trip!
Cheers all and here's to wishing everyone a Happy New Year!
Rob
Series 1 86"
Post #485462 26th Dec 2015 4:14am
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
Brewstop wrote:
This thread is comprehensive land rover porn for me - Thank you!
What he said!!^^^^^ Thumbs Up
Merry Christmas My confidence has been writing cheques that my abilities can't cash for years.
Post #485512 26th Dec 2015 1:17pm
