![]() | Home > Puma (Tdci) > Puma EGR blanking plate FREE :-) |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Yes, I put the normal gasket back in this evening. I'm hoping to that the light will go off after driving it a bit like Pete suggested. I look forward to hearing the ECU results when you find out more.
What I dont understand is that with the plate everything sounds normal with lights, why aren't there any lights for what I thought was a faulty EGR in the first place? ![]() I was wondering if disconnecting the cable off the EGR valve itself might get rid of the light? cheers |
Verdone Member Since: 30 Apr 2008 Location: Gent Posts: 67 ![]() ![]() ![]() |
Yeah beats me, and ive thought of that aswell, but thats gonna put the light on aswell ![]() ![]() Ah well lemme know how it goes i'm leaving it on for now ![]() Greetings Verdone |
Ur light gone now mrwoo?
I'm still waiting for that scanguage ![]() Greetings Verdone |
Yes, it's gone out again now after around 50 miles of driving. I think like Pete said it's needs around 3 driving cycles to clear it down. Cheers Rich |
So we can deffo say it hasnt damaged anything ![]() And hows the engine now, back to its old self again? Greetings Verdone |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
It wont damage anything by blanking , at the worst it will do what its already done on some of them , put a light on that should auto clear once the ecu sees that its not a permanent DTC.
Because we know that the fault was caused by the blanking its not possibile for it to store as permanent so in every case it should as a mater of course clear its self. Regards Pete |
dave's 110 Member Since: 11 Jun 2008 Location: Norfolk Posts: 45 ![]() ![]() ![]() |
Just looking how you fit this blanking plate I see the cup holder on top of the engine cover has a cap on it should they all have this as mine hasn't got one and didn't from new
IS it best to fit blanking plate if have ECU remap would it help run better ? Dave |
Mine doesnt have that cap either mate but theres no use for it, just use for what u said as a cupholder or a place to put your screws while thinkering around in the engine bay, best thing about the ford engine ![]() ![]() Greetings Verdone |
ANY NEWS ON THE FAULT CODE YET?
6 working days now and still no package, its coming from greece but still, im gonna send an e-mail because i need it
![]() I will let u know once i got it mrwoo ![]() Greetings Verdone |
Thanks Verdone that's great. |
Mrwoo,
I got the scanguage and its a nice little handy thing, i found the error and deleted it and it stays gone for now, done a bit of driving already so hopefully it will stay away ![]() U can see lots of stuff on this scanguage, how much mpg etc etc u r getting, rmps, motor temperature, and the list goes on lol. Anyways the engine is still going strong without the annoying rumble on tick over so i am VERY happy ![]() Oh the error was massflow air sensor in range but higher then expected so nuthing to worry bout ![]() Greetings Verdone |
Verdone are you running the standard air filter ??
Regards pete |
Yeah didnt change anything there, i have a mantec snorkle though.
Greetings Verdone |
