Home > Puma (Tdci) > Puma EGR blanking plate FREE :-)
Did this plate make any difference to your cars running.
Made no difference
20%
 20%  [2]
Made my car better and i will post the results
80%
 80%  [8]
Made my car worse and i will post the results
0%
 0%  [0]
Total Votes: 10
Page 6 of 12 <123 ... 567 ... 101112>
3WHouse
Russia 2007 Defender 110 Puma 2.4 SW Java Black
What if to clean a gear?
 Def`s 90 & 110 Monochrome.
You can go fast i can go anywhere.))
http://www.offroadpower.ru/
Post #17373 28th Oct 2009 9:23am
Caterham
those gears......call me stupid (most people do) but that ain't an EGR is it?
Post #17375 28th Oct 2009 9:41am
3WHouse
Post #17392 28th Oct 2009 11:34am
fabiocasta
Italy 2008 Defender 110 Puma 2.4 SW Stornoway Grey
x pete
Hi,
I'm fabio from Modena (I), my yellow light is on... uff...
in my 90 td4 I have connected the cluch pedal swich with a button on the console.
when I push this button, the ECU disables the EGR immediatly, because is like to push the cluch pedal. Did you know? Is possible to use this information to deceive the ECU for turn yellow light off?
Thanks
Fabio
Post #19337 2nd Dec 2009 6:44pm
dgardel
Italy
Thanks
Fabio
Ciao Fabio
Are you sure about that?
If you blank the EGR (I disconnected mine months ago, yes with yellow MIL lamp always on) you have the MIL ON:
1. Ecu read more MAF value (MAF signal higher but in range)
2. Ecu read more MAF value (EGR Orifice restricted)
and, if you disconnect the EGR
3. 2 errors about ecu circuit functionality check
and....
when you "by-pass" the clutch switch, the Ecu is too much "rapid" when you push and/or release the throttle and the transmission are "under attack" Mr. Green what do you think about that? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #19339 2nd Dec 2009 7:13pm
dgardel
Italy
Exhaust Gas Recirculation valve: in same condition part of exhaust gas are "deviated" to the inlet manifold; in this way the combustion have less oxygen and the combustion temperature are a little low.
less temperature means less NOx productions Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #19340 2nd Dec 2009 7:17pm
fabiocasta
Ciao Dgardel
i don't have disconnected the EGR!!!!!!! The button disconnects only the pedal cluch switch.
( ho praticamente bypassato il switch del pedale della frizione in modo che in fuoristrada, agendo sul bottone, la risposta del pedale dell'acceleratore è immediata e si pou' telegrafare. La centralina, mentre vai, agendo sul pulsante pensa che tu sia con il pedale premuto e chiude subito l'egr; si sente immediatamente, basta tenere il ga costante e cambia la risposta, il rum ore, l'erogazione... ecc. Magari questa info puo' essere utile a chi rimappa, nel caso in cui si tappi l'egr, per creare un ragionamento che inganna la centralina)
Sorry....it is italian....
ciao
Fabio
Post #19361 3rd Dec 2009 8:46am
dgardel
Italy
En:
Fabio, it's "sound" strange, that the status of the clutch switch will able to close the EGR.
I have a data OBDII recorder and, during the weekend (I hope), I' test this so we'll be sure about the EGR status when we operate on clutch switch...
It:
Fabio, mi sembra strano che chiuda del tutto l'EGR. Ho un datarecorder OBDII con cui posso vedere i parametri in funzionameto tra cui la % di apertura dell'EGR.
Non per mettere in discussione la tua parola, ma per essere sicuro, vorrei vedere se accade e come accade.
Daniele Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #19362 3rd Dec 2009 8:59am
fabiocasta
x dgardel
no problem!!!! I may be wrong.
we could meet someday... My friend Michele lives in Venice (Mestre)....
Ciao
Fabio
Post #19374 3rd Dec 2009 11:35am
dgardel
Italy
fabiocasta wrote:
x dgardel
Ciao
Fabio
Absolutely YES!!!!
ti mando una mail con il mio cellulare, call me
IID Pro MV License
Post #19382 3rd Dec 2009 2:14pm
WinBoot
Belgium
Sorry to bump this thread, but how about placing a resistor on the sensor cable? So rather then finding the out of bound values it thinks it's normal?
Post #21680 9th Jan 2010 1:45pm
Tim seymour
Australia
HI I HAVE HAD MINE BACK AND THEY REPLACED THE ERG VALVE. JUST HOW LONG THIS ONE WILL LAST. HAS ANYONE GOT ANY IDEAS THAT WORK AND LEAVES THE DASH LIGHT OUT THANKYOU TIM :
Post #22279 17th Jan 2010 12:36pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Welcome Tim, we know you're a long way away but please don't shout especially on a Sunday morning Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #22280 17th Jan 2010 12:50pm
Tim seymour
Australia
Hi i wont shout this but has anyone done anymore testing on the erg thankyou tim
Post #22682 22nd Jan 2010 10:22am
K9F
Pm'd Pete of BAS last week with exactly the same question - With the blanking plate fitted there was currently no resolution with regards to the MIL light coming on yet was the answer. Welcome to the site by the way! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #22683 22nd Jan 2010 10:38am
