Home > Puma (Tdci) > New MY2011 door uderseal, who know more than me???
Page 7 of 8 <12345678>
nickhodgson
Has anyone fitted these seals to an older Defender where the original seal was on the floor and not on the door?
Post #220841 21st Mar 2013 9:37am
DLK
Netherlands 1986 Defender 90 200 Tdi SW Zambezi Silver
I'd like to know that aswell. I replaced the seals on the floor already but there are some mighty big gaps in the corners...
Post #220856 21st Mar 2013 11:16am
Happyoldgit
They will fit all models with the pressed door frames with round corners but not those on earlier 90's & 110's which had welded frames and square corners. Steve.
http://forums.lr4x4.com
Post #220881 21st Mar 2013 1:17pm
First90
2010 Defender 90 Puma 2.4 HT Alpine White
Great post! The existig seals on my 2010 90 are a sick joke.
Post #222716 27th Mar 2013 10:21pm
older defenders don't have door bottoms ... all the metal falls out browny/orange colour Very Happy
Post #222775 28th Mar 2013 8:05am
Happyoldgit
While the lower door skins dissolve into white powder Whistle Steve.
Post #222904 28th Mar 2013 4:00pm
Is there any possible noise reduction with these? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #274191 16th Oct 2013 10:26am
Roby466
United Kingdom 2000 Defender 110 Td5 CSW Java Black
I have a 2000 and although my door frames are welded, it is tempting to give these seals a try. The older model seals fitted on mine is simply useless and all dried out. The fit may not be perfect with these newer seals on a 2000 but the shape of the door seems to be similar to the new ones although not quite as smooth... Anybody else has tried to fit them on a welded up door frame?
Post #275192 20th Oct 2013 9:13am
ibexman
how do you drill the front door corners , release door stay ??
Post #293512 27th Dec 2013 10:56pm
Mean Green
They do fit older doors too. I fitted the drivers side yesterday and about to do the passenger side now. Relatively easy fit - could be done in about 15 mins - but I ended up rubbing down and painting the door frames etc so took most of the day.
Not had a chance to drive it yet so dont know if they make any difference to noise or drafts but they do fit.
And Ibexman - yes just whip off the dowel in the door stay and there is easy access to the front corner.
Post #293841 29th Dec 2013 10:42am
Mech
I'd like to fit new seals, but I'm a bit overwhelmed by the various types. Hopefully one of you pro's can set me straight.
I recently bought a reconditioned 200tdi 110. The dealer fixed the rusted out door bottoms prior to purchase. However, they did not use any plastic liner material behind the door cards. Further, I don't see any drain holes in the bottom that folks have mentioned in previous posts. Most of all they leak like a sieve. I get water running down the interior side of the seal and onto the floor board. The seals themselves are twisted and battered. I know I need new ones, I'm just not sure which ones are best. My truck currently has the riveted on bottom seal attached to the body vice the door.
Should I...
1.) Buy some allmakes seals
2.) Fit them with some silicone
3.) Add a plastic liner to the inside of the door card
4.) Drill some drain holes into the bottom of the door frame and waxoyl the cavity
5.) Remove the riveted bottom seals from the body.
6.) Fit some of these new style seals to the door?
Post #296683 7th Jan 2014 9:20pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I upgraded mine at the weekend. I found the cheapest place to get them was at the Land Rover dealer. £55 for the 2 seal after cheekily asking if there was any discount for knowing the part number Smile
As usual, details written up in my blog.
[url] http://defender90xs.blogspot.com/2014/08/u...html[/url] http://defender90xs.blogspot.co.uk/
Post #352759 20th Aug 2014 7:44pm
HardCharger
Hi All!
Reviving this thread as I noticed gaps in my door seals, as in I can see light coming in! I think this is also where outside odors come in for us to enjoy at times. Mad
In any case, mine is also a MY2011 but the seals look nothing like the ones in the post. Previously, the gaps were closed with rubber cubes the previous owner stuck on but I've lost a few already as evidenced by the light and external odors coming in. Left side inner front carpet is wet too from what I think is spray that gets in when passing through water.
Are the part numbers posted on this thread still accurate? Seeing as these seals are different, I'm thinking of changing them all out. So I need front and rear seals, are there updated Safari door seals as well?
Thanks!
Post #481210 11th Dec 2015 6:38am
Cat81
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Orkney Grey
They are the right reference. I changed my old ones today to the new style. I can still see daylight in one of the rear door front corners, though. This is frustrating as I thought it would take care of the issue for good! The seal seems to pull up as the door closes, which creates the gap.
Anyone had that issue before? The other three doors look fine.
Post #481891 13th Dec 2015 9:38pm
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
i noticed BARMACH have the same part number- whats the diff?
Post #578081 16th Nov 2016 4:29am
