excossack Member Since: 22 Feb 2012 Location: North West Posts: 5897 ![]() ![]() ![]() |
Thanks for the tips. My heater isn't that bad, takes a while to get there. Is it just the top dash off? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
It's much easier to take the top, centre stereo section and passenger side centre section completely off (it's not that much extra work and makes it all a lot easier) and just unscrew and let the clocks dangle as you will need to pull about on the inner bracing to get the wheelboxes in as they are fiddly.
Also the drivers side vent needs taking out to replace the drivers side wheelbox.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20651 ![]() ![]() |
Put this on:
![]() Click image to enlarge In case you haven't noticed already it's the CSK decal just below the bonnet. ![]() (Sorry Chris but I took the .co.uk off. ![]() ⛽️🛢️⚙️🧰💪 |
red-scirocco Member Since: 28 Jun 2012 Location: South Norfolk Posts: 13 ![]() |
Continued chasing my wheel bearing noise around my truck!
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
Look better lower and in white ![]() ![]() ![]() |
@custom90steve What's cable tied onto your A-Bar ? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
[quote="gavinpm"]
hi gavin, i was the first owner and had the vehicle delivered directly to j e engineering in coventry. they did the koni suspension, remap, intercooler and silicon hoses plus the lights in the grille and the rev counter in the dash (clock moved next to rear view mirror); bourton land rovers cut the side windows into the hardtop, plus cut the rear bulkhead down, fitted the checker plate, rear nas lights and step, too. have you kept all the ICE - its not ground breaking loud but has good bass and treble. the sports exhaust was by twisted and just makes you want to drop a gear and go ![]() i miss my old truck ![]() |
To keep the spots cables tidy. ![]() ⛽️🛢️⚙️🧰💪 |
Ahh, makes sense now! Cheers ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Not sure if you mean the sticker or your just joking about the whole thing but I could have put on a white decal of the same thing but black is so much more 2013. ![]() ![]() ⛽️🛢️⚙️🧰💪 |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
![]() Just need the LR badge to match now. ![]() ![]() ⛽️🛢️⚙️🧰💪 |
