Page 450 of 1382 <123 ... 449450451 ... 138013811382>
gavinpm
England 2006 Defender 90 Td5 SW Cairns Blue
[quote="farmer giles"]
gavinpm wrote:
Collected some windfall wood....
gavin - you've got my old 90 Thumbs Up Thumbs Up Thumbs Up
how do you like the performance and the stereo? Cool
Great to hear from you farmer.
I'm loving it - so you did all the mods did you ?
Gavin
Post #211338 15th Feb 2013 9:08am
excossack
mk1collector wrote:
It is pretty much but if your ok with a screwdriver and have a good memory it's not too bad. I took the oppertunity of the dash being out to cable tie all the wires securely to stop rattles and to tape and insulate the heater pipes and insulate as much bulkhead as I could at the same time. As you probably know the heater is in the td5 is pretty poor so every bit helps and the pipes leading to the vents were hardly in the sockets so well worth duct taping in place!!
Thanks for the tips. My heater isn't that bad, takes a while to get there.
Is it just the top dash off? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #211339 15th Feb 2013 9:10am
mk1collector
It's much easier to take the top, centre stereo section and passenger side centre section completely off (it's not that much extra work and makes it all a lot easier) and just unscrew and let the clocks dangle as you will need to pull about on the inner bracing to get the wheelboxes in as they are fiddly.
Post #211344 15th Feb 2013 9:29am
mk1collector
Also the drivers side vent needs taking out to replace the drivers side wheelbox.
Post #211345 15th Feb 2013 9:30am
Put this on:
In case you haven't noticed already it's the CSK decal just below the bonnet. Cool
(Sorry Chris but I took the .co.uk off. Whistle ) KEEP CALM AND Drill ON
Post #211418 15th Feb 2013 4:15pm
red-scirocco
Continued chasing my wheel bearing noise around my truck!
Post #211425 15th Feb 2013 4:38pm
barbel jim
custom90steve wrote:
Put this on:
Look better lower and in white Rolling with laughter Rolling with laughter Rolling with laughter
Post #211430 15th Feb 2013 4:44pm
GUM97
@custom90steve What's cable tied onto your A-Bar ? An engine to TDi for!
Post #211432 15th Feb 2013 4:46pm
farmer giles
[quote="gavinpm"]
Gavin
hi gavin, i was the first owner and had the vehicle delivered directly to j e engineering in coventry. they did the koni suspension, remap, intercooler and silicon hoses plus the lights in the grille and the rev counter in the dash (clock moved next to rear view mirror); bourton land rovers cut the side windows into the hardtop, plus cut the rear bulkhead down, fitted the checker plate, rear nas lights and step, too.
have you kept all the ICE - its not ground breaking loud but has good bass and treble.
the sports exhaust was by twisted and just makes you want to drop a gear and go Whistle
i miss my old truck Sad
Post #211433 15th Feb 2013 4:51pm
To keep the spots cables tidy. Thumbs Up KEEP CALM AND Drill ON
Post #211437 15th Feb 2013 4:53pm
GUM97
Ahh, makes sense now! Cheers Thumbs Up An engine to TDi for!
Post #211438 15th Feb 2013 4:55pm
Not sure if you mean the sticker or your just joking about the whole thing but I could have put on a white decal of the same thing but black is so much more 2013. Whistle Mr. Green KEEP CALM AND Drill ON
Post #211489 15th Feb 2013 7:16pm
barbel jim
Thumbs Up
Post #211570 15th Feb 2013 11:55pm
Killer90
Site Sponsor
Put this on:
Thumbs Up looks the nuts mate thanks for the advertisement Mr. Green Mr. Green CSK Automotive
www.cskautomotive.co.uk
Post #211571 16th Feb 2013 12:04am
Thumbs Up
Just need the LR badge to match now. Whistle
Post #211632 16th Feb 2013 11:04am
