Home > Puma (Tdci) > Recalls for the puma?
Page 1 of 4 1234>
lornick
Scotland 1988 Defender 90 300 Tdi HT Epsom Green
Guy's,
Is there a concise list that exists detailing all the recall's issued for the puma since it's release in 2007? I'm not asking for a list of everything that's gone wrong with everyones vehicle here - just the official factory notices issued relating to fixes.
I'd like to be able to ring the dealer and ask him if all the recall work that was required has been done on my vehicle- but would prefer to do so with a list in front of me.
Thanks (in anticipation.....)
Post #15281 9th Sep 2009 5:06pm
mse
Recalls there are only 2 - Sump and Brake Pipes
Service actions there are more (not definitive):
Vacc Pump
Propshaft Greese Nipples
Clutch
Breather
A frame bolts (very early)
Brake Pad Rattle
Jack Rattle
Intermittent Cranking
A cold markets one
There are a couple other incidental ones Mike
Post #15282 9th Sep 2009 5:40pm
Eduardo
I was informed of a new campaign here regarding the ECU software that must be changed.
The problem was the sensor's sensibility to low quality diesels. The changes allows lower quality fuels without had errors in the ECU.
Ive not have access to the Landrover techinfo so I cannot confirm.
Cheers Eduardo
Post #15285 9th Sep 2009 8:10pm
lornick
Recalls
Thanks,
I'll give the main stealer a call tomorow and see if he can tell me if they've been done.
Rgds
Post #15288 9th Sep 2009 8:55pm
scatt
England 2008 Defender 110 Puma 2.4 DCPU Alpine White
Im trying to get the ecu update at the moment but im told the update has been put on hold because its causing more problems than it solving. Crying or Very sad .
Post #15292 9th Sep 2009 9:17pm
Eduardo
Scatt,
I just speak today with the dealer and he told me about the ECU update. Maybe has been released again for 3rd world countries were the diesel are not good.
Tomorrow I will be there again for replace a joint-propshaft in the front propellor due an excesive wearing (62.000 km) and they will do the ECU update.
Cheers Eduardo
Post #15293 9th Sep 2009 9:30pm
dgardel
Italy
Eduardo wrote:
Scatt,
Ok Edo, waiting your feedback
Post #15297 9th Sep 2009 10:46pm
mse
I wouldnt want it - the latter remap was shocking compared to mine Mike
Post #15299 9th Sep 2009 11:28pm
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I think i had this remap done yesterday. Confused
We don't have 3rd World Diesel in Aus, as far as I'm aware (10PPM Sulphur)?
Seems to have increased the mid range torque. Have an even bigger grin on my face now.
Dave
Post #15302 10th Sep 2009 1:09am
Eduardo
Humm,
We will see what happens
Here also the diesel is quite good with less than 50 PPM in the Capital and less than 350 ppm in the rest of the country (should be the best in Central and South America).
It is possible after made the update comeback to the old one?
Cheers Eduardo
Post #15303 10th Sep 2009 2:02am
Grockle
ECU reflash was pulled in Aus and other export markets earlier this month. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #15337 11th Sep 2009 9:01am
BigGeorge
Switzerland 2010 Defender 110 Puma 2.4 SW Keswick Green
Below a collection of service bulletins / not aware of a real recall.
Regards
George
Nr 1)
Technical Service Bulletin
No.LTB00177
09 October 2008
Subject/Concern: Brake Vacuum Pump Seal Oil Leak
Models:
Defender (LD) 2.4L Diesel Only
2.4L Diesel Only VIN-range: 7A732615 Onwards
Markets: All
Section: 206-07
Summary: Oil leaking from the brake vacuum pump front oil seal.
Cause: Dirt ingress into the pump pulley seal resulting in damage to the lip and subsequent oil leakage (the new brake vacuum pump has a secondary dirt lip seal). Suggested Customer Concern Code - R31.
Action: Should a customer express concern, install a new brake vacuum pump (refer to Global Technical Reference GTR Workshop Manual, section 206-07 (70.15.19)).
Parts Required:
Description Part Number Quantity
Brake vacuum pump LR012183 1
Gasket LR004381 1
Labour Time:
Operation Description Operation No. Time
Install a new brake vacuum pump 70.15.19 0.7 hours
Repair/Claim Coding:
Causal Part: LR012183
ACES Condition Code: 42
Defect Code:
Nr.2)
Land Rover Service Bulletin SSM38792, 2.4 Puma Engine Knock Noise.
Title: 2.4 Puma Engine Knock Noise.
Type: LD - Defender - All Years - Special Service Messages - Engine
Name / Part No: SSM38792
Info Type: Service Bulletins
Version No: 1
Date Uploaded: 21 Jul 2008
Models: LD - Defender
Last Modified: 21-JUL-2008 09:44
Category: Engine
Symptom: 497000 Engine Noise
Content Issue: Heavy audible knocking heard on start up.
Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur.
Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used.
This condition will not occur on vehicles post assured Vin# 9A767162.
Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed.
Nr. 3)
SSM39893
Models
LD - Defender
Title Defender Intermittent Cranking
Last Modified 26-NOV-2008 16:29
Category Electrical
Symptom 203000 Basic Electrical
Content Issue:
Warranty investigations have shown a number of repairs to Defender for intermittent loss of cranking.
Cause:
This issue may well be due to the immobilisation strategy on Defender.
Action:
Before conducting any work on a vehicle with this symptom, please view SSM 34184.
Nr.4)
SSM38084 Models LD - Defender
Title Defender MA 07 - lock in one gear
Last Modified 06-MAY-2008 11:27
Category Transmission
Symptom 505000 Manual gearbox anomalies
Content
Reference: MT82 Getrag gearbok locked in one gear.
Cause: Still not determined.
Required action: Land Rover ask to the dealers to confirm the problem first and proceed to fill the attached questionary before to get in contact with the "Fix Right Enhanced Diagnostics" (FRED) technichians in charge of the repairs. Thats will allow to the enginnering dept to understand the possible causes of the problem.
Nr.5)
SSM40851
Defender Front and Rear Propshaft Grease Points
Models : LD - Defender
Title: Defender Front and Rear Propshaft Grease Points
Last Modified: 30-MAR-2009 08:27
Category: Noise/ Vibration
Symptom: 703000 Vibration Concerns
Content Issue: Loose or missing front / rear propshaft grease nipples for Defender 07 MYonward vehicles.
Action: If any propshafts are identified where the grease nipples are missing, then the propshaft should be replaced. Any cases where the grease nipples are in place but loose should be torqued to 8Nm + 45degrees.
Nr.6)
Models
LD - Defender
Title P1169 and or P0089 codes logged.
Last Modified 30-JUL-2008 10:16
Category Driveability
Symptom 608000 Runs Rough
Content Issue:
07MY onwards - Difficult to start, missfire, lack of power, driveability issues etc.
PCM can have either P1169 and or P0089 logged codes.
Pre assured Vin# Def 90 at Vin LD8A760582. Defender 110/130 at Vin# LD8A760304.
Cause:
Potential contamination in the fuel system.
Action:
Remove the fuel filter, drain complete contents into a suitable clear vessel. Note signs of any water contamination / debris. 1) If more than 40cc of water or debris is evident carry out the following:-
Drain the fuel tank.
Check the fuel tank breather location and reposition as per the illustration A attached.
On pick up variants please reposition the breather pipe in board towards the rear of the fuel tank.
If breather is blocked replace the pipe as per GTR.
Replace the fuel filter and clean out the fuel lines of any contamination / debris and or residue.
For P1169 code replace the FMV (Fuel Metering Valve), as per GTR and LTB00153. Illustration B.
If DTC P0089 is also present replace the PRV (Pressure Relief Valve), as per GTR. Illustration C.
Bleed and prime the fuel system as per GTR.
Start the vehicle and carry out the pump learn process with IDS as per GTR.
Carry out a road test to ensure the issue has been rectified and no codes have been logged.
Submit any findings on ePQR to engineering.
2) If no sign of water or debris but either codes logged carry out the following:-
Check the integrity of the wiring and the condition of the terminal connections between PCM and Fuel Rail Pressure Sensor and between PCM and FMV. Repair wiring as necessary and re test the vehicle.
If no issue is found with the wiring / connections, and code P1169 logged, replace the FMV as per GTR and LTB00153.
Replace the fuel rail PRV (Pressure Relief Valve), only If DTC P0089 is present as per GTR.
Note:-
A new tank / breather design was introduced on Defender 90 Vin# LD8A760582. and Defender 110/130 at Vin# LD8A760304.
Please submit an ePQR for any issue seen on vehicles post these vins.
Nr.6)
SSM40308
Models
LD - Defender
Title Mulitiple Starter Motor Failure
Last Modified 21-JAN-2009 17:43
Category Electrical
Content
Issue:
Repeat failures on Defender starter motors.
Cause:
The ignition switch can jam causing starter motor failure due to over running.
Action:
If the starter motor has failed check operation of ignition switch;
a) Is the switch jammed through any of its positions?
b) Does the switch fully return to position 2 once cranked and the inhibit operates, not allowing re-crank from position 2?
c) Does the starter motor continue to engage once cranked and key released?
If the answer to any of the above is YES please change ignition barrel as well as starter motor as potentially the starter motor will fail again.
Vehicles post vin. 775971 have been modified and should not demonstate this concern.
Nr.7)
LTB00166
Subject/Concern: Clutch Noise/Poor Selection
Models:
Defender (LD) 2.4 Puma Diesel Engine. 2.4 Puma Diesel Engine. VIN-range: 7A732615-9A766150
Markets: All
Section: 308-00
Summary:
Potential difficult gear selection and noise in clutch operation.
Cause: Improvements have been made to the specification of the clutch plate and clutch cover to
address both the potentially difficult gear selection and noise during clutch operation
concerns.Suggested customer concern code P24.
Action: Should it become necessary to install the clutch kit assembly, refer to the new procedure
detailed in Global Technical Reference GTR Workshop Manual, section 308-00.
Parts Required:
Clutch kit Assembly. URB500080 1
Labour Time:
Clutch kit Assembly Renew. 33.10.01 3.9 hours
Causal Part: URB500080
ACES Condition
Code:
Nr. 8
Technical Service Bulletin No.LTB00211
30 April 2009
Subject/Concern: Transmission Stuck in Gear, Selector Shaft Detents Now Available
Models: Defender (LD) 2.4 Puma Diesel 2.4 Puma Diesel VIN-range: 7A732615 Onwards
Markets: All
Section: 308-03
Summary: This Technical Bulletin is to advise that the transmission selector shaft detents are now available as a serviceable part. Therefore it is no longer necessary to replace the complete transmission assembly for concerns related to the transmission selector shaft detents (transmission stuck in gear).
Should it become necessary to replace the transmission selector shaft detents, refer to the new procedure detailed in Global Technical Reference GTR Workshop Manual, section 308-03.
Parts Required:
Transmission Detent Kit LR017294 1
Labour Time:
Selector Shaft Detents – renew 37.16.75 4.9 hours The goons are trying to bring me down!
Defender 110 SW MY10 useless piece of Censored ... but I like her
Defender 90 V8 50th Anniversary
Series IIa 109 / 6 cyl. ex-fire truck
Post #15338 11th Sep 2009 9:21am
mse
Sump and Brake pipe were recalls
The rest on my list were service actions Mike
Post #15343 11th Sep 2009 10:47am
BigGeorge
what was the issue with the brake pipes?
here in switzerland the owner were not contacted for recalls. It was me who had to produce the bulletin to get the oil sump changed... they had no clue!
George The goons are trying to bring me down!
Post #15354 11th Sep 2009 1:34pm
mse
The brake pipe was rubbing on the heat sheild and failing (some posts on here) and failing: 206-Q054v2:
A limited number of 2007/8MY Defender vehicles may have been manufactured away from
process and in some cases; the rear brake pipe may have been incorrectly routed/fitted resulting
in reduced clearance/contact with the heat shield. If the rear brake pipe is in contact with the
heat shield, this may result in the brake pipe wearing through.
Action to be taken
You are requested to contact the owners of the affected vehicles and request that the vehicle is
made available at the earliest opportunity so it can be inspected and where necessary the brake
pipe be re-routed or replaced. A sample customer letter for you to use is attached as Appendix 1.
The workshop procedure is attached as Appendix 2.
Mine went in and they couldnt better my bodge fix but the sump it was in being changed when the sales dealer called me to book it in. Mike
Post #15358 11th Sep 2009 1:59pm
Page 1 of 4 1234>
