![]() | Home > Puma (Tdci) > Clutch exchange |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
I counted 9 coils in the springs, is that right? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
That is the "new" type with "white" teflon!
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2469 ![]() ![]() ![]() |
there are 3 types. Puma 110" SW
MacDefender Member Since: 17 Aug 2011 Location: Caxias do Sul Posts: 16 ![]() ![]() ![]() |
My 2007 110 has a new complete clutch for more than a year. I dont know what brand is, but sseems to run more smooth than the original one. God help me.....
Just got a call from LR, they are replacing the entire clutch assembly under warranty. Only took 2 years of complaining #smh --
CONGRATS!!!!!!!!!
It was like expecting! ![]() Hope your issues will also be sorted now...... |
Haha, indeed! I'm going to go down to the stealer later and inspect the new clutch kit. I will take pics and a video to see if this one rattles out of the box -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
This is the clutch that is going in, looks the same to me:
![]() Click image to enlarge ![]() Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
Did it rattle like the last one?
Still in the box, they are putting it in this afternoon. I will report back once I get the landy back. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Looks like 3rd type. All plates rattle a bit. I�m not sure why but might be a design issue in order to get some free play due to the ![]() ............................................................. Earth first. Other planets later |
How can you tell? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
less coil turns and more separated. Or maybe is something between 2nd and 3rd
![]() DIdn�t get worse since you fit the lift? Puma 110" SW ............................................................. Earth first. Other planets later |
Now that you mention it, it does look like there are only 8 coils per spring.
I honestly don't think so -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
