Home > Puma (Tdci) > Clutch exchange |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2637 |
I counted 9 coils in the springs, is that right? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
8th Jun 2012 10:08am |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 |
That is the "new" type with "white" teflon!
8th Jun 2012 11:25am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2411 |
there are 3 types. Puma 110" SW
8th Jun 2012 8:32pm |
MacDefender Member Since: 17 Aug 2011 Location: Caxias do Sul Posts: 16 |
My 2007 110 has a new complete clutch for more than a year. I dont know what brand is, but sseems to run more smooth than the original one. God help me.....
10th Jun 2012 12:08am |
Just got a call from LR, they are replacing the entire clutch assembly under warranty. Only took 2 years of complaining #smh --
13th Jun 2012 8:52am |
CONGRATS!!!!!!!!!
It was like expecting! Hope your issues will also be sorted now...... |
13th Jun 2012 8:58am |
Haha, indeed! I'm going to go down to the stealer later and inspect the new clutch kit. I will take pics and a video to see if this one rattles out of the box -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
13th Jun 2012 8:59am |
This is the clutch that is going in, looks the same to me:
Click image to enlarge Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
13th Jun 2012 10:43am |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 |
Did it rattle like the last one?
13th Jun 2012 11:01am |
Still in the box, they are putting it in this afternoon. I will report back once I get the landy back. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
13th Jun 2012 11:02am |
Looks like 3rd type. All plates rattle a bit. Iīm not sure why but might be a design issue in order to get some free play due to the flywheel which cannot absorb some turning kicks of the cycle. Puma 110" SW ............................................................. Earth first. Other planets later |
13th Jun 2012 1:24pm |
How can you tell? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
13th Jun 2012 1:31pm |
less coil turns and more separated. Or maybe is something between 2nd and 3rd
DIdnīt get worse since you fit the lift? Puma 110" SW ............................................................. Earth first. Other planets later |
13th Jun 2012 1:36pm |
Now that you mention it, it does look like there are only 8 coils per spring.
I honestly don't think so -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
13th Jun 2012 1:40pm |
