![]() | Home > Puma (Tdci) > Clutch exchange |
Cat81 Member Since: 05 Mar 2014 Location: Kent Posts: 60 ![]() ![]() ![]() |
Clutch changed on 2010 2.4 at c. 30k miles. Under extended warranty no questions asked.
Mongolia Member Since: 23 Jun 2013 Location: Toulouse Posts: 45 ![]() ![]() |
Clutch changed on MY2007
1st time at 60000 km (warranty) 2d time at 195000 km (1 spring out so no gear) |
puma2010 Member Since: 09 May 2012 Location: glos Posts: 28 ![]() ![]() ![]() |
Hi everyone, 2010 puma 28000 miles third clutch now fitted free of charge by Strastone cheltenham. Very smooth none cluncky non rattley clutch, hope it stays that way.
caterham6 Member Since: 18 May 2014 Location: Manchester Posts: 47 ![]() ![]() ![]() |
2010 0n a 90......12,000 mile Easy Life..No Clutch...
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
2011 73000kms/45000mile => no clutch change.
Kvenmon Member Since: 15 Aug 2014 Location: Gratangen Posts: 2 ![]() ![]() ![]() |
2007, 149000km 1. clutch !!! One spring loos, replaced by my self this weekend.
funrover Member Since: 12 Dec 2010 Location: Yorkshire Posts: 130 ![]() ![]() ![]() |
2008 at 44000, one clutch change (the inner spline had begun to work free and was causing a thudding sound when changing gear as well as a metallic rattling sound). Editor of FunRover - One blog. Read it!
Land Rover rebuild video series here: |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
190.000 km and 2 clutchs now
![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
With a rattly clutch, but not completely failed (i.e. still driveable), once replaced how would you describe the drive - massive improvement or not noticeable.
Also, did you take the opportunity to have the intermediate drive to transfer box inspected / replaced? Cheers Andy To answer sure my own question, its a massive improvement, in fact the backlash in the drive train can hardly be felt ![]() Cheers Andy Last edited by ROBBONTHEROCK on 1st Jul 2017 8:43am. Edited 1 time in total |
proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 ![]() ![]() ![]() |
2008 90 SW with 75000kms no clutch change in paperwork but sometimes particularly when warm very rattling in neutral. Perhaps I consider soon to do a change myself and also other jobs of opportunity.
Buwster Member Since: 26 Jun 2014 Location: Fgura Posts: 35 ![]() ![]() ![]() |
Mine went last week, 2007 with 60,000 miles. Clutchfix going in!
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4258 ![]() ![]() ![]() |
Is there a way to change my response? Did it wrong cos I'm a moron! 2007 110 TDCi Station Wagon XS
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
def puma 2.2 2012 clutch have problems at 131.000km I am lucky, just go back from hollidays ! I think, 130.000km is not a lot, but when I read here, I see a lot did have it very early Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Clutch replaced on my truck (XS 110, 07MY);
1st clutch replaced under warranty (circa 2008); 2nd clutch replaced June 17 (78k); Replaced with clutch fix kit and new modified clutch hydraulics, all parts supplied by IRB. Old Clutch:- [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] PS Old clutch was fitted in 2008 and his marked as such, also output adapter shaft had no grease, it wasn't badly rusted but showing signs of it starting to rust (78k miles). Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
