Home > Puma (Tdci) > Clutch exchange |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
As usual (and expected), they compared the noise to a similar and a new Puma and their response is that they all sound the same and thus must be normal.
Time to escalate to LR South Africa -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
24th May 2012 2:41pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2440 |
Such technic is used worldwide and me off!. No Defender is like any other. They should know it. Puma 110" SW ............................................................. Earth first. Other planets later |
24th May 2012 10:26pm |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 |
2010 Fire 90 Ltd.
49000km Clutch to be changed on Monday. |
2nd Jun 2012 8:17am |
At lest they agreed to do it. LR CL is not even trying to book mine in to confirm that it needs to be changed. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
2nd Jun 2012 9:23am |
ja, must say, we have a very good tech foreman at Centurion LR.
Will see on Monday how much I will have to pay in...... |
2nd Jun 2012 9:28am |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 |
07/2010, 53.000km, still the first clutch and so far no problem at Ditec with that at least.
2nd Jun 2012 9:30am |
For a 2-year old clutch? NOTHING! I would refuse to pay anything, this is caused by their sh*tty design, not your driving style. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
2nd Jun 2012 9:33am |
did you vote? (for the stats) Puma 110" SW ............................................................. Earth first. Other planets later |
2nd Jun 2012 1:30pm |
Yip, my vote is cast p.s. When they took the clutch out 3 of the 4 springs was loose/out/broken but my Defender realy still drove very, very nicely except for that slight rattle/vibration in low gears Just shows you.......... who needs a clutch in any case...... |
4th Jun 2012 1:34pm |
hectic! If they are going to fit a heavy-duty clutch, do you have the part number? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
4th Jun 2012 1:41pm |
Ja, I feel the same way about it But spoke to 3 other lads who had theirs replaced and LR see it as a wear item and in most circumstances the owners had to pay 30%odd of the new clutch..... |
4th Jun 2012 1:45pm |
Asked them but they wont fit it for me.......apparently they will only fit it if you can proof that you use the car for heavy towing daily |
4th Jun 2012 1:57pm |
I will give them a fight they will remember. Last time I hired a lawyer who wrote them a nice letter. Then it was Yessir, whatever you want sir.
now what kind of batsh*t thinking is that!? I'll ask for one anyway and see -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
4th Jun 2012 3:43pm |
Is there such a HD clutch? Puma 110" SW
5th Jun 2012 2:04am |
