Home > Maintenance & Modifications > All-in-one Multimedia & GPS solution? |
And it is strange because Japan is RHD Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
20th Feb 2012 3:05pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20294 |
Mine: http://www.justkenwood.co.uk/car-audio.aspx/kfc-s1093-speakers Annoyed though that the grill has rusted in the back |
20th Feb 2012 3:40pm |
mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86 |
I've just ordered one of these, will only be of use to iPhone holders, but after weeks of searching I felt this seemed sensible as I can use my existing iPhone TomTom app and all other apps, plus when I leave the car, there's not really a stereo to nick:)
http://www.caraudiodirect.co.uk/oxy-ocar-oxygen-audio-ocar.htm |
21st Feb 2012 12:04pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2637 |
Link does not work -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
21st Feb 2012 12:14pm |
Sorry try this:
http://www.oxygenaudio.com/o-series/363-o-car.html |
21st Feb 2012 2:32pm |
Ah, but that's for people who use crapples -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
21st Feb 2012 3:03pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
I've got the Oxygen unit, the idea is nice but the reality is not so great
You download two apps, one for the radio, the other for sound adjustment, the first problem is you have to come out of the radio app (so radio turns off) in order to go into the sound app so you cant hear the changes you make. The second is, in 'portrait' mode in the Puma your hand hits the iphone when changing gear. Thirdly, you cant listen to the radio whilst doing anything else on the iphone ie navigation Its also quite bulky in the dash, as I said, nice idea but not as thought out as it could be |
21st Feb 2012 3:07pm |
Matt - do you have v1.2 of the head unit, i think this has all changed now.
21st Feb 2012 3:16pm |
Probably not, I've had it a while - is there a way of upgrading ?
21st Feb 2012 3:24pm |
Thanks for looking, I've emailed them through their site
21st Feb 2012 3:45pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Well, my Pioneer AVH-6300BT does all the functions i need from the I phone, calls, music, films etc, has a separate mike for the Parrot BT phone , works well
Good to see you here Matt California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
21st Feb 2012 6:24pm |
Knot Yet Member Since: 01 Mar 2010 Location: West Sussex Posts: 197 |
We recently, last week, purchased one of these, works great so can only assume its a firmware issue on yours Matt Defender 110 Puma Utility XS |
21st Feb 2012 8:13pm |
Kraut Member Since: 28 Dec 2011 Location: Westphalia Posts: 336 |
Matt, would you be so kind to post a solution for upgrading the old firmware, in case oxygen sends an answer? I have one of the first units too, therefore no parallel usage of radio and other apps.
Thanks very much in advance! Kraut |
22nd Feb 2012 7:31am |
I am getting rid of the Pioneer and fitting the Philips CED229. Does the same thing, but has SD card, which means no obstruction for the LCD screen
Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
22nd Feb 2012 8:29am |
