![]() | Home > Maintenance & Modifications > All-in-one Multimedia & GPS solution? |
Finally got he Pioneer installed, and decided to throw in a pair of 4" JBL to replace the OEM front speakers - wow, now the sound in the landy is awesome!
The Pioneer is very nice, but it is very slow compared to 'normal' head units. A bit like working in Windows 95 as opposed to Linux ![]() The tuner is the most impressive part - never have I seen a head unit where the FM quality was better than my MP3s! One of the sound shops I was dealing with now has the Philips CED229 in stock, I may go have a look and if the latter is faster, I will swap the Pioneer for that one. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
If your Rhd then I found the USB lead gets in the way of the display
Yep, found that out yesterday. Easily solved by adopting USB thumb drives. Also one of the reasons to go for the Philips - it takes SD cards. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20761 ![]() ![]() |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
I'd really be inclined to have a look at that one in the flesh before buying it. I was convinced that would be the one to go for until seeing it, the GUI is bit old fashioned and screen quality doesn't compare to the latest kenwoods, which is a shame. It is a 3 year old model I was told so that may be the reason. I'm hoping they might bring a revamped model out Seems to work ok though and has a garmin sat nav as an accessory so that should be quite good, so not all bad ![]() It may be that we are being spoilt a bit with iPads, iPhones and expect too much from stuff nowadays for the money. Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
I have the previous one to that again the KVT 726 and I find that does everything I want. I also have fitted the 526 in the flesh which has a few more different features and easier with less cabling to install but other than that I think they're great. Another reason I chose them was because as far as I know Kenwood originated in the UK. Plus it had to match the kitchen appliances
KVT-729 Closed
![]() Click image to enlarge KVT-729 Open ![]() Click image to enlarge Not thinking of upgrading as the 526 isn't that much different. ![]() |
Becker Cascade Pro
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
that thing would not survive the gravel roads we travel, which is why I needed a headunit with a built-in screen with as few moving parts as possible -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
You'd be surprised how well built and strong they are though ![]() |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
Bluetooth Sony head unit, ram mount and an iPad 2. All I need and will likely ever need. GPS, Memory map and co-pilot stop me getting lost.
Ipad2, best bit of technology kit I have ever brought. =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
I also replaced the front dash-mounted speaker with a pair of JBL GTO series, made a *huge* difference
![]() ![]() Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
What power output do those have? ![]() |
IIRC 35W RMS and 100 Peak. But the quality of high frequencies is sooooo much better! -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
