![]() | Home > Maintenance & Modifications > All-in-one Multimedia & GPS solution? |
Yeah, I'm also thinking that's the way forward. Amp/sub will have to be on the back of the cubby box, it's a 90. Or else have the audio shop make an enclosure that fits between the safe and the cubby box? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
A sub and amp, along with some nice 6x9s are a godsend in my 90, it is really up there in my 'must do' mods.
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
![]() Click image to enlarge 8" jl sub in the back of the cubbybox. my new set up has the amp in the cubbybox with the jl sub mounted ontop with a metal grille over it - i think the sould is better now. greeni - where did you mount your 6x9s? |
youused dynamat on this at all. I'd like to insulate and quieten down the 110 ready for some tunes, Theres room for a sub under the rear seat of the 110 ![]() |
It sure is !!!!! Lots of it too, double layered on the wheel tubs !
good, worth every penny in these thngs, did you do doors and roof aswell? |
No, I've never really had time strip it all out, though it's a must...
My head unit is a Sony with an 'aux' in plug, the iphone plugs in and I use it as an Ipod, also phone calls come through the speakers and it works as an hands free...double bonus. As for reverse cameras, if I don't see it in my mirrors, I stop when I hit it ! |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
That was my philosophy until I wrote off a Renault Clio, still only a broken reversing light on mine. |
Nice! Is that a 'slimeline' JBL sub? Do you have the model number please? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
The joys of Defender ownership...my green 90 had more hits than the Bee Gees, never damaged it ! |
hi naks, ![]() its a bog standard 8" sub; i will look through my old invoices tonight to see if i can find a part number. the car audio specialists recommended NOT going for the slimline underseat option as they know that my taste is for full bass not just enhanced bass. i prefer the sub pointing upwards in my 110 and the grille is very robust (18 month old son walks on it!). |
After weeks of searching high and low, I finally settled on the Pioneer DVH-735av:
![]() Click image to enlarge Decided to keep the GPS separate as there's nothing wrong with the Garmin unit I have now. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
What you will find oh your LHD so UR Ok
err, nope, we're RHD in South Africa ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
